Will USDM parts fit JDM motor?
Old Oct 3, 2005 | 08:11 AM
CantGetRich's Avatar
Default Will USDM parts fit JDM motor?
I am about to purchase a jdm B16a2 and was wondering if usdm parts will fit a jdm motor? I want to replace the waterpump, distributor cap, spark plugs, plug wires and alternator. Which motor should i buy these parts for? Also which gaskets and oil filter will i need? Thanks for the help
Old Oct 3, 2005 | 09:18 AM
Downey's Avatar
Default Re: Will USDM parts fit JDM motor? (CantGetRich)
Yes, the usdm parts will fit the jdm motor. there is no difference between the motors other than compression ratio and the manifold might have a few different vacum ports.
For timing belt and water pump, get one for a 94-95 del sol vtec (b16a3) or a 99-01 civic si (b16a2). plugs, wires, cap & rotor are usualy all the same for the dohc vtec motors. anything for a b16, b17, b18c should do you fine.
FlewByU352
Oct 9, 2009 04:01 AM
Abius
11
Jan 21, 2008 03:51 AM
SOHC_4dr
Jun 20, 2006 10:08 AM
stealthhatch
Apr 30, 2004 10:44 PM
Evan
Aug 29, 2002 06:04 AM
