CEL ecu code #43 Fuel supply system . . . .anyone know about this?????
Old Oct 3, 2005 | 05:27 AM
KiD Fr0m Da 516's Avatar
Default CEL ecu code #43 Fuel supply system . . . .anyone know about this?????
have had a stock ls in my ej for 3-4 months now, never a CEL until the past few days its code 43 Fuel supply system, and in all honesty i dont know where to start looking for this problem, you think you guys could help me out . . . .I was thinking maybe a fuel pump or maybe injectors - thanks Jason
Old Oct 3, 2005 | 06:07 AM
Brodie Bruce's Avatar
Default Re: CEL ecu code #43 Fuel supply system . . . .anyone know about this????? (KiD Fr0m Da 516)
How is the car runnning? If there are no driveability problems it is most likely your O2 sensor.
Old Oct 3, 2005 | 06:55 AM
yea theres not problems at all, idled funny the first 2 months due to a fuel problem and now its fine, should i just swap out the o2 sensor with mine?
Old Feb 17, 2006 | 11:22 PM
type Gendy's Avatar
Default Re: (KiD Fr0m Da 516)
Ever fix your problem? I'm having the same issues
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KiD Fr0m Da 516 &raquo;</TD></TR><TR><TD CLASS="quote">yea theres not problems at all, idled funny the first 2 months due to a fuel problem and now its fine</TD></TR></TABLE>
What fuel issue made it idle funny? Because my swap is doing the same thing!
Old Feb 20, 2006 | 06:35 PM
93CharcoalHatch's Avatar
Default Re: (type Gendy)
im having the same code 43 problem swapped O2 sensor and its still there... anyone know what to look at next?
Old Feb 20, 2006 | 07:16 PM
type Gendy's Avatar
Default Re: (93CharcoalHatch)
up for not wanting to fork out mad cash on o2 sensor to have same problem
Old Feb 20, 2006 | 07:46 PM
speedfreek128's Avatar
same happend with my B18B in my EG......think it might be I wired the new O2 wrong or there is a vac leak somewhere.....read in a manual it has to do with fuel pressure/fuel regulator and poss vac leaks....when i change my TB gasket Ill check everything out and let yall know if it went away
Old Feb 20, 2006 | 09:04 PM
type Gendy's Avatar
Default Re: CEL ecu code #43 Fuel supply system . . . .anyone know about this????? (speedfreek128)
jdm206
13
Dec 6, 2007 01:06 AM
Sleepy_Red_hatch
Apr 23, 2007 08:15 AM
PhilStubbs
Jan 22, 2005 11:20 AM
dcsportsciv
10
Nov 12, 2004 06:44 PM
OBDI JEDI
May 7, 2003 05:06 PM
