ls intake mani. on b16?? how too
Old Oct 2, 2005 | 07:37 PM
sloweredcivic's Avatar
Default ls intake mani. on b16?? how too
i have seached for this and didn't find any really good right ups.
my dilema i have a venom drag manifold for a ls motor but i have a b16 can this be modified to fit. if so how hard is it? i mean the retail on this is like 650 so i don't really want to pass it up.
Old Oct 2, 2005 | 08:48 PM
Nerologic's Avatar
ur not going to find write on how too..
because no one does this...
ur best bet is cutting the LS flang off and having some one weld a B16 one on....
Old Oct 3, 2005 | 05:02 AM
is that the only way cause had found threads about b16 manifols on ls motors
Old Oct 3, 2005 | 11:24 AM
Nerologic's Avatar
yup, because the b16 manifold flows better, hence they never went backwards...
Old Oct 3, 2005 | 01:28 PM
you realize i am wanting to put a venom DRAG manifold on the b16 right its just off of a b18a1. it would flow beter than most aftermarket b16 mani's
Old Oct 3, 2005 | 03:21 PM
doesn't some one know how??
Old Oct 3, 2005 | 03:48 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (sloweredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweredcivic &raquo;</TD></TR><TR><TD CLASS="quote">you realize i am wanting to put a venom DRAG manifold on the b16 right its just off of a b18a1. it would flow beter than most aftermarket b16 mani's</TD></TR></TABLE>
Most intake manifolds including the Venom one, make less HP than the 2nd gen (P30) B16 manifold. In fact, if the P20 manifold gets polished it will yeild the highest reults for most b series all motor applications.
If running boost, thats a diffferent matter, i would look to a JG Edelbrock manifold for that.
Old Oct 3, 2005 | 03:58 PM
CRX Toad's Avatar
Default Re: (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">
If running boost, thats a diffferent matter, i would look to a JG Edelbrock manifold for that.</TD></TR></TABLE>
Wow, you get a gold star by your name. Good info
Old Oct 3, 2005 | 04:02 PM
Autoworks's Avatar
Default Re: (CRX Toad)
The only way is to cut the flange off of a B series and weld it. If you ever take a LS intake mani gasket and a B16 intake gasket you'll see how very different they are.
N/A I think you would notice minimal gains with that type of manifold. for the time and $$ spent, you could get a different mani with less the headache.
Old Oct 3, 2005 | 06:19 PM
actually i was going to switch form a dry setup to a dirct port setup and the manifold is only 200 bucks
Old Oct 4, 2005 | 01:48 AM
Nerologic's Avatar
on a NOS car i doubt this manifold will yeild hi gains (unless they were lectrons carbs or ITBS) so id ditch it...
just sell it....
DIABOLIC8
Aug 13, 2009 03:44 PM
jmankush
Sep 23, 2006 08:35 PM
straightline
Mar 22, 2003 07:07 AM
Ri5e
Jul 24, 2002 07:01 PM
