shorter shifter, not a short throw shifter?
Old Oct 2, 2005 | 07:09 PM
Kyles ej1's Avatar
Default shorter shifter, not a short throw shifter?
i like how in some cars the shifter is shorter and doesnt sit as high, like in bmw's. is there a company or something i can do to have the actual shifter shorter?
im not talking about a short throw shifter!!
Old Oct 2, 2005 | 07:15 PM
Kendall's Avatar
Any good welder should be able to handle this for you.
Old Oct 2, 2005 | 07:20 PM
pdiggitydogg's Avatar
yeah, just cut the stock one and ghetto shift all down the street.
Old Oct 2, 2005 | 07:26 PM
Kyles ej1's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">yeah, just cut the stock one and ghetto shift all down the street.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Any good welder should be able to handle this for you.</TD></TR></TABLE>
would that be safe though?
Old Oct 2, 2005 | 07:31 PM
viskii420's Avatar
yeah bro.. u dont hurt the trany.... might be slightly harder to change the gears.. cuz shorter grip .. but thats about it
Old Oct 2, 2005 | 07:32 PM
Exactly. The shifter is a lever, if its shorter it will be harder to change gears (and reach)
B&M shifters are shorter physically (had one), cheap, and are a "short shifter"
Old Oct 2, 2005 | 07:34 PM
Luserkid's Avatar
You could cut it and take a die to it. Thats another idea.
Old Oct 2, 2005 | 07:39 PM
civic_driver's Avatar
if i were to do it, i'd do what luserkid suggested.. good luck!
Old Oct 2, 2005 | 07:42 PM
Kendall's Avatar
Assuming it's correctly TIG welded back together there should be no problems. I've seen many shifters done like this.
Old Oct 2, 2005 | 08:46 PM
GetawayInMoscow's Avatar
Default Re: (Kendall)
Short Shifters don't hurt the tranny. Idiots hurt tranny's.
Old Oct 2, 2005 | 08:53 PM
komat's Avatar
Default Re: (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">Short Shifters don't hurt the tranny. Idiots hurt tranny's.</TD></TR></TABLE>
its from them letting go of the clutch early and grinding hte gear or they slam it into gear?
Old Oct 2, 2005 | 09:11 PM
Kyles ej1's Avatar
Default Re: (komat)
they slam it into gear.
and when i asked if it was safe i didnt mean for the tranny, i was worried about the weld breaking or something if i got it cut and welded
Old Oct 2, 2005 | 09:16 PM
MonkeyBoy668's Avatar
Default Re: (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">You could cut it and take a die to it. Thats another idea. </TD></TR></TABLE>
You could also cut it and use an aftermarket **** that doesn't rely on threads. Cutting the shifter will make the **** sit lower, which sounds like what you want, and give a minimal "short throw" improvement.
Old Oct 2, 2005 | 09:25 PM
_gurusan_'s Avatar
Default Re: (MonkeyBoy668)
Most cheapass Ebay shifters are shorter than stock.
I have one i got for 15 shipped a year ago and it's doing fine
Old Oct 2, 2005 | 09:27 PM
Jorsher's Avatar
Eh I've heard bad things about those cheapass ebay ones. Somethin like they're hollow and break. Personally I wouldn't want a shifter to break whiel I'm driving.
I forgot what the company was, but someoen sells short shifters for 30-50 bucks that are solid aluminum. You should try search.
SoyMilk
Jul 12, 2007 08:39 AM
mraza
18
Apr 10, 2007 08:53 AM
ProjectCD5
Feb 21, 2006 11:55 PM
hcivic99
11
Jan 2, 2005 08:47 PM
SMC Integra
Jul 23, 2004 05:08 PM
