Front Grille
Old Oct 2, 2005 | 06:05 PM
zerokool1128's Avatar
Default Front Grille
On the 99 ex, i ordered a new front grille. Aside from the plastic rivits on the top, what else do I need to remove to replace it?
Old Oct 2, 2005 | 06:07 PM
ekcivic9's Avatar
the screws that are attaching it to the bumper?
Old Oct 2, 2005 | 06:31 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: Front Grille (zerokool1128)
https://honda-tech.com/zerothread?id=1389147
Old Oct 2, 2005 | 07:01 PM
SupraCivic's Avatar
Default Re: Front Grille (EJ8VTEC)
On my 97 all I had were the plastic screws on the top. Like 5 of them or so??
Thats it.
Old Oct 2, 2005 | 08:29 PM
CivicSlid3's Avatar
Default Re: Front Grille (SupraCivic)
Really, my 97 hatchie I have to remove the whole bumper to get to the 5-6 screw in the inner core that connect grille to bumper. Youre lucky supracivic. Does anyone know if the screws in the inside of the grille come off with flathead or phillips screw driver??
Old Oct 2, 2005 | 09:16 PM
areyoujealous's Avatar
Default Re: Front Grille (CivicSlid3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSlid3 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if the screws in the inside of the grille come off with flathead or phillips screw driver?? </TD></TR></TABLE>
phillips from underneath
Old Jan 12, 2006 | 07:41 AM
bump
Old Jan 12, 2006 | 07:54 AM
SovXietday's Avatar
You won't be able to get it off if you still have the rain guard (that big plastic sheet: w/e it's called) underneath the car. You'll need to remove the bumper to pull it out, then the new one you ordered you can put on by just pushing it in and screwing it on top.
Old Jan 12, 2006 | 08:57 AM
HondaEJ7's Avatar
i took off front bumper..removed 7 clips that attached to the radiator support...then 4 screws (2 under bumper and 1 in each wheel well) and it came off..then there are i believe 6 phillips screws and the grill with the middle emblem and edge molding come off together
M1SCO15
Nov 5, 2006 07:17 PM
cd5_2NR
Jul 28, 2004 02:02 PM
2ksilverex
10
Apr 27, 2004 06:19 PM
slowone
Jun 26, 2003 02:09 PM
Lewd Lude
Jun 22, 2001 02:46 AM
