Turbo 2nd gen zc question...
Old Oct 2, 2005 | 05:43 PM
sleepin91teg's Avatar
Default Turbo 2nd gen zc question...
Friend of mine has a 92-95 2nd gen dohc zc that he has boosted, needs to know what ecu to use for it...his car is a 92 and is also obd-1 i cant think of what ecu to use before going to hondata...thanx guys!
Old Oct 2, 2005 | 07:32 PM
xenocron's Avatar
Default Re: Turbo 2nd gen zc question... (sleepin91teg)
for a non-vtec OBD1 setup...use any chipped P05, P06, PR4 or P75 ECU
EDIT: You can use any OBD1 VTEC ECU as well...just disable VTEC in whatever editor you are using.
Old Oct 2, 2005 | 08:09 PM
Default Re: Turbo 2nd gen zc question... (xenocron)
With no editor right now...just need an ecu to run on...only boosting 5-6psi right now, nothing big, just need the ecu for the setup...
Old Oct 2, 2005 | 09:08 PM
second edition's Avatar
ive got a po5 on crome..works well
Old Oct 2, 2005 | 11:18 PM
liam821's Avatar
25 Year Member
If you are talking about running a *stock* ecu (ie not chipped) there is three ecus you can run which will work (without codes)
p06 (92-95 sohc dx non-vtec): will work, will run lean though
p74/p75 (92-95 dohc LS ecu): will work, runs rich, fuel/ignition tables all wrong
p29 (obd1 dohc ZC): this is the one you really want
p28 (sohc vtec): will run the engine okay (prolly run a little lean on the topend without the vtec map enabled), but you will have a CEL
I run a p28 chipped ecu with Neptune on my dohc ZC. I run with vtec enabled (even though it does nothing) so i have more resultion on the topend (i rev my motor to 9000). Ive also run Uberdata back in the day also on a p28.
liam
Old Oct 3, 2005 | 07:12 AM
Default Re: Turbo 2nd gen zc question... (liam821)
Liam, again i appreciate all the questions you have ever answered of mine...but ive never heard of a p29 so im guessing its rare and probly jdm...Where can we get one? i just looked through classifieds and saw nothin...he doesnt wanna go standalone yet, just something to drive on...hes using a d15 ecu, and it runs, but not near where it should...Thanx again!
-Joshua
Old Oct 3, 2005 | 11:38 PM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepin91teg &raquo;</TD></TR><TR><TD CLASS="quote">Liam, again i appreciate all the questions you have ever answered of mine...but ive never heard of a p29 so im guessing its rare and probly jdm...Where can we get one? i just looked through classifieds and saw nothin...he doesnt wanna go standalone yet, just something to drive on...hes using a d15 ecu, and it runs, but not near where it should...Thanx again!
-Joshua</TD></TR></TABLE>
The p29 is from a EG5, its a 92-95 eg with an obd1 dohc ZC. The ecu is somewhat rare and hard to find - its out there though.
You can always chip a p28/p06/p74/p75 ecu and install the p29 program. You can find the p29 BINARY on pgmfi.org and chipping the ecu is cheap.
liam
Old Oct 4, 2005 | 03:29 AM
bennyhonda7's Avatar
hey what year zc you all running black or brown top...and where did you get the obd1 dizzy? im doing this swap soon also.?
Old Oct 4, 2005 | 04:30 PM
liam821's Avatar
25 Year Member
Default Re: Turbo 2nd gen zc question... (bennyhonda7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bennyhonda7 &raquo;</TD></TR><TR><TD CLASS="quote">hey what year zc you all running black or brown top...and where did you get the obd1 dizzy? im doing this swap soon also.?</TD></TR></TABLE>
Im running a 3rd gen dohc ZC (black top). This block is out of the EG5, its a obd1 motor, so it came with a obd1 dizzy, obd1 wiring, obd1 fuel injectors etc. It was a simple swap into my 93 civic SI.
If you are doing a swap into a obd1/2 car, i highly recommend you start with a obd1 motor - save yourself alot of trouble.
liam
DAtegLs
Dec 22, 2009 10:56 PM
chaos304k
Oct 5, 2007 10:06 AM
Markb16a
Nov 27, 2006 05:51 PM
blaze_32001
Jul 11, 2006 02:53 PM
NorcalHB94
Aug 27, 2004 05:56 PM
