Temp. control slider hard to move...
Old Oct 2, 2005 | 05:35 PM
oilguzzler's Avatar
Default Temp. control slider hard to move...
Hey, my temp adjuster(the thing that adjusts the temp in the cab) Is hard to move. Lie if its at cold i hae to push it 2/3 across, its pretty rough, then to get it to hot i have to literally ram it. It dies this going back to. What could be wrong with it?
Old Oct 2, 2005 | 05:50 PM
integra_si-vtec's Avatar
hey mine was like that too, and i did it so hard that it broke. i would like to know what is wrong with it too!
Old Oct 2, 2005 | 07:14 PM
Nataku's Avatar
Default Re: (honda-tech'er)
just posted about this a week ago man. going to try lubing it tomorrow hopefully.
Old Oct 2, 2005 | 10:46 PM
b18c-1's Avatar
Default Re: (Nataku)
just take out the climate control and lub the cable
Old Oct 2, 2005 | 11:27 PM
2G0S0R1's Avatar
New User
Default Re: Temp. control slider hard to move... (oilguzzler)
to easily see if it isnt due to lack of lubrication... start unconnecting the metal line loops that connect to the valves associated with the slider. There is one directly under the dash, and one connected to the heater core bypass under the hood, and also one up by the drivers feet/dash i think.
Remove them one at a time and then try the slider, if it is hard at all after disconnecting all of them... then it is the line or the slider assembly.
Old Oct 5, 2005 | 01:41 PM
oilguzzler's Avatar
It almost sounds like a flap or something in the dash that it catching or something. The guy before me remved the dash cause the odometer had been rolled back. Could he have messed with something?
Old Oct 5, 2005 | 07:28 PM
2G0S0R1's Avatar
New User
messing with the odometer doesnt necessitate removing the dash, just the cluster. I doubt he screwed with the entire dash unless he told you that.
Old Oct 5, 2005 | 07:30 PM
PnoyJeff's Avatar
mine is like that too..not sure why but i would think that something in there is too tight...but i dont know
Old Oct 6, 2005 | 12:39 PM
EnjoyTheRideDC2's Avatar
Default Re: Temp. control slider hard to move... (PnoyJeff)
To remedy the problem, just pull out the temp console and throw vaseline/petro. jelly on the cable and the surrounding area.
dE.fUsEd
Aug 28, 2013 06:12 AM
rolledthatho
Jan 24, 2011 08:28 AM
FlewByU352
Aug 29, 2010 07:03 PM
chitownrida
Feb 22, 2007 12:38 PM
Zoso1977
Nov 6, 2004 10:57 PM
