AutoZone legend rotors part number
Old Oct 2, 2005 | 05:24 PM
01-0720's Avatar
Default AutoZone legend rotors part number
i did a search and found two different part numbers
i just want to know which one is correct
im looking for the part number to the autozone legend rotors that
fit on type r's, the ones that are like 22 bucks
thank you for any and all help
Old Oct 2, 2005 | 05:29 PM
SlapSmak's Avatar
Default Re: AutoZone legend rotors part number (01-0720)
this is the correct part #, use them myself...
https://honda-tech.com/zerothread?id=181691
Old Oct 2, 2005 | 05:44 PM
nsxtasy's Avatar
H-T Order of Merit
3296
Did you know that you can go into Autozone's website, specify a car (e.g. 1998 Acura Integra Type R), click on "Shopping", and you can find the Autozone part numbers for most frequently-replaced parts?
Old Oct 2, 2005 | 05:50 PM
1GreyTeg's Avatar
Default Re: AutoZone legend rotors part number (nsxtasy)
3296 is the Duralast and same ones I use.
Track tested and multiple Type-R owner approved
Old Oct 3, 2005 | 04:37 AM
01-0720's Avatar
Default Re: AutoZone legend rotors part number (1GreyTeg)
yeah but i thought the ones for the type r were like 46 and the ones that are for the legend were only 24 and they were the same thing?
Old Oct 3, 2005 | 04:44 AM
Willard's Avatar
$25/each
They work just fine.
Old Oct 3, 2005 | 05:43 AM
01-0720's Avatar
Default Re: AutoZone legend rotors part number (Willard)
yeah those are the ones im buying
Old Oct 3, 2005 | 07:56 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">yeah but i thought the ones for the type r were like 46 and the ones that are for the legend were only 24 and they were the same thing?</TD></TR></TABLE>
No. You're probably thinking of how the Autozone rotors for the ITR are $25 for front rotors but $49 for rear rotors. Or maybe you're thinking of brake pads (whose cost is different but so is the composition)...
Old Oct 3, 2005 | 08:41 AM
baonest's Avatar
2 year warranty, its been like a year and ive already swapped them out 4 times. (swapped each time i hit the track).
Old Oct 4, 2005 | 11:52 AM
jond's Avatar
Default Re: (baonest)
Wow.. Acura front Rotors are $110 each! Looks like I'm hitting up autozone...
Old Oct 4, 2005 | 12:08 PM
Circuit Star-29's Avatar
Default Re: (jond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">2 year warranty, its been like a year and ive already swapped them out 4 times. (swapped each time i hit the track). </TD></TR></TABLE>
What rotors are you using?
Old Oct 4, 2005 | 12:14 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (jond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">Wow.. Acura front Rotors are $110 each!</TD></TR></TABLE>
No, they're not. They list for $90.33 and you can get them for $72.26 from Delray Acura.
Old Oct 4, 2005 | 02:05 PM
R6Boy69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">3296 is the Duralast and same ones I use.
Track tested and multiple Type-R owner approved </TD></TR></TABLE>
I am gonna see what i can get them for we have the same numbering system at my work
Old Oct 7, 2005 | 01:20 PM
UNDERGROUNDAUTOSALON's Avatar
Default Re: AutoZone legend rotors part number (R6)
awesome tip, thanks
Old Oct 7, 2005 | 01:23 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: AutoZone legend rotors part number (UNDERGROUNDAUTOSALON)
The type r rotors are only 25 bucks, about the same price as legend rotors.
pricing varies upon your location.
Old Oct 7, 2005 | 02:38 PM
Default Re: AutoZone legend rotors part number (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">The type r rotors are only 25 bucks, about the same price as legend rotors.
Maybe true but the legend rotors are thicker...I haven't warped mine and Im very hard on rotors. Plus the pads I was using have eaten ITR rotors up very quickly in the past. The legend rotors have no visiable wear which is enough for me...and they haven't warped which is nice when Im driving around on the road.
Old Oct 7, 2005 | 03:09 PM
MugenHonda's Avatar
Default Re: AutoZone legend rotors part number (C-speed Racer)
lol what's the part number then?
I purchased the itr rotor set but i will return them for the legend ones?
You guys try advance?
Their parts are much better quality and cheaper
Old Oct 7, 2005 | 03:20 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">lol what's the part number then?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">$25/each
They work just fine. </TD></TR></TABLE>
Wha else do you need that hasn't been posted already?
Old Oct 7, 2005 | 03:50 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">Wha else do you need that hasn't been posted already?</TD></TR></TABLE>
Whether or not those slightly thicker Legend rotors are OK with Sp00m calipers.
Then again, I guess that extra 2-3mm might not be that much of an issue.
Old Oct 7, 2005 | 03:57 PM
1GreyTeg's Avatar
Default Re: AutoZone legend rotors part number (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">
Then again, I guess that extra 2-3mm might not be that much of an issue.</TD></TR></TABLE>
Well if they fit stock calipers and brand new pads I don't think there'd be much of an issue
Old Oct 7, 2005 | 06:42 PM
an2ny888's Avatar
i'm curious as to where the autozone rotors are manufactured. are there any markings on the rotors indicating where they were made?
Old Oct 8, 2005 | 03:29 AM
1GreyTeg's Avatar
Default Re: AutoZone legend rotors part number (an2ny888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">i'm curious as to where the autozone rotors are manufactured. are there any markings on the rotors indicating where they were made?</TD></TR></TABLE>
iirc, China.
Old Oct 10, 2005 | 05:07 AM
Willard's Avatar
IIRC... the last box of Aimco units were made in the USA. I will check the box this evening at the house and see where they were made.
Old Oct 10, 2005 | 06:02 AM
baonest's Avatar
Default Re: (C-speed Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-speed Racer &raquo;</TD></TR><TR><TD CLASS="quote">
What rotors are you using?</TD></TR></TABLE>
sorry for the late reply. its the autozone rotors.
Old Oct 10, 2005 | 07:35 AM
pcorad's Avatar
Maybe true but the legend rotors are thicker</TD></TR></TABLE>
Autozone's website shows the same part number for the Legend and ITR rotor: 3296. How can there be a difference in width?
