ls b18 swap into 1990 civic hatch?
Old Oct 2, 2005 | 04:07 PM
ProjectJDMIntegra's Avatar
Default ls b18 swap into 1990 civic hatch?
I crashed my integra and i want to my my b18 into my 1990 civic hatch. Is this going to be hard to do, and i am guessing now a direct swap. Will the axle's from the tegra work, or do i have to get something else. Not sure how to go about this, it is my first one on a car. ALL help appriciated!!
Old Oct 3, 2005 | 02:35 AM
Default Re: ls b18 swap into 1990 civic hatch? (ProjectJDMIntegra)
anyone?
Old Oct 3, 2005 | 11:00 AM
DB1_559's Avatar
what year integra
Old Oct 4, 2005 | 01:56 PM
Default Re: ls b18 swap into 1990 civic hatch? (jdmboi86)
1992
Old Oct 5, 2005 | 12:47 PM
EFvtec Yo!'s Avatar
Yeah your axles will work if your integra was a 92. As far as mounts you will need aftermarket ones to put a b series motor in that hatch. If your hatch is not an si you will also need to do dpfi-mpfi wiring conversion. You will also need an aftermarket shift linkage or your could either cut and modify the one out of the integra.
Old Oct 8, 2005 | 06:56 PM
HondaCivicSiR1's Avatar
Default Re: (EFvtec Yo!)
also if you have a dx you will have to change you wheel assembly's i know because that's what i had to do on my ef dx hatch good luck with your swap
Old Oct 10, 2005 | 03:04 PM
DB1_559's Avatar
try this website call hybrib honda or look it up on google that will help u alot
DaViiS
May 2, 2016 08:19 PM
Jmay258
Jan 22, 2008 11:59 AM
spooncivicsi
13
Apr 3, 2006 09:37 AM
2ndGenIntegra
10
Jan 12, 2006 12:51 PM
ProjectJDMIntegra
Oct 2, 2005 03:41 PM
