eg gsr doesn't feel like it has the potential it should
Old Oct 2, 2005 | 01:17 PM
Tealeg88's Avatar
Default eg gsr doesn't feel like it has the potential it should
yo what up i have a eg hatch with usdm gsr. I have dc sports header, skunk2 manifold, and intake and exhaust. I also have chipped p28 to go with my setup. I feel like my car doesnt pull the way it should. I've been to cheap to get it dynoed because im kinda short on some cash, but i ran it at the track and my best time was 15.00. It seems to rev a little slow. The reason i think it revs slow is because ive drive my brothers eg coupe with a b16 and his revs alot faster. I have no check engine lights or anything. I feel like my car should be pulling a little better than what is now but i dont know what could be wrong and where to start. If anyone can let me know how i can start trouble shooting to know what may be restricting its power. Any help would be appreciated. Thank you
Old Oct 2, 2005 | 01:21 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: eg gsr doesn't feel like it has the potential it should (Tealeg88)
A worn stock clutch could cause a loss in pull. Just my $.02 since this could really be a ton of ****...
Old Oct 2, 2005 | 05:37 PM
Tealeg88's Avatar
Default Re: eg gsr doesn't feel like it has the potential it should (HondaFanatic708)
sorry i forgot to mention i have a stage one act clutch. so that cant be it, and it also grabs decently.
Old Oct 2, 2005 | 05:52 PM
Could be the chip, poor/inproper fuel and ignition maps will definitely do this. Who built the maps for ya?
Old Oct 3, 2005 | 10:36 AM
Tealeg88's Avatar
this guy that advertises on on honda-tech. His website is j-k-tuning.com. He told me that i would need to get it tuned after words using crome or uberdata, but i dont know if thats gonna do it. I may think it might have somthing to do with fuel or with distributor. Sometimes when im cruising in 5th gear at 60mph and i take of the gas i almost feel as if the car hesitates a little. I also feel al little hesitation in the lower rpm when im in other gears. It's not a big hesitation just a slight bit but i think that has something to do with the problem.
Old Oct 3, 2005 | 01:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tealeg88 &raquo;</TD></TR><TR><TD CLASS="quote">this guy that advertises on on honda-tech. His website is j-k-tuning.com. He told me that i would need to get it tuned after words using crome or uberdata, but i dont know if thats gonna do it. I may think it might have somthing to do with fuel or with distributor. Sometimes when im cruising in 5th gear at 60mph and i take of the gas i almost feel as if the car hesitates a little. I also feel al little hesitation in the lower rpm when im in other gears. It's not a big hesitation just a slight bit but i think that has something to do with the problem.</TD></TR></TABLE>If you maps aren't tuned to the engine that could certainly cause the problem..
Old Oct 3, 2005 | 01:56 PM
Tealeg88's Avatar
ok that sounds good than the only problem is the closest tuner in my area that uses crom is 6 hours away. If anyone knows a tuner that is located near chicago illinoes please let me know.
Old Oct 3, 2005 | 02:52 PM
EGmikeH22's Avatar
* B A N N E D *
PMd
Old Oct 3, 2005 | 04:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tealeg88 &raquo;</TD></TR><TR><TD CLASS="quote">ok that sounds good than the only problem is the closest tuner in my area that uses crom is 6 hours away. If anyone knows a tuner that is located near chicago illinoes please let me know.</TD></TR></TABLE>If someone has a computer and a chip burner they can tune it for you, but really the only way is on a dyno..
Old Oct 3, 2005 | 04:18 PM
-Gambit-'s Avatar
do a compression check on the motor.
eskerley
11
Nov 28, 2008 11:00 PM
JapanRide
11
May 17, 2005 05:04 PM
Eziekel
32
Oct 12, 2003 01:00 AM
