POLL: What brand of oil do you use???
A good resource for oil info is http://bobistheoilguy.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris91DA »</TD></TR><TR><TD CLASS="quote">royal purple
if you want it on there...you have to add it to the list!!!
Modified by H22PwrdHatch at 3:12 PM 10/2/2005
</TD></TR></TABLE>if you want it on there...you have to add it to the list!!!
if i had the money i would use Mobil-1, but since i change oil every 2500 ( i dont see the point of high dollar oil ),so i use castrol syntec. 10 bucks for a a 5qt bottle. and 5 bucks for wix filter, you cant go wrong with that -)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C »</TD></TR><TR><TD CLASS="quote">I'm using Mobil 1 0w-40.. It's a good A3 rated motor oil.</TD></TR></TABLE>
this guy knows whats up
some castrols syntecs on the market are A3 as well..
and also BMW 5w30 oil (which is made by castrol) is also A3 rated.
so is redline, but way to overpriced for my budget.
ACEA A3
(look on the back of the bottle, the rest of the inferior oils will have ACEA A1 on the back)
ACEA A3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL »</TD></TR><TR><TD CLASS="quote">
ACEA A3
(look on the back of the bottle, the rest of the inferior oils will have ACEA A1 on the back)</TD></TR></TABLE>
I was a GC user until the green became extinct. Can the Castrol BMW oil be purchased at any BMW dealership?
ACEA A3
Is royal purple an ACEA A3 oil?
I'm gonna give that BMW Castrol a shot for my next oil change, i'll be sure to get an oil analysis for it as well.. maybe compare that vs. M1 0w-40
Modified by LSVT3K 91 C1V1C at 4:36 PM 10/3/2005
My last B16 burned though a quart of Mobil 5w30 between changes. It barely drank any Royal Purple. For any kind of performance setup I run royal purple, for anything else I just use Castrol GTX.
Any 5w-30 dino oil will do the trick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvboost »</TD></TR><TR><TD CLASS="quote">what type of oil should i use for a start up on my new lsvtec??....its a used block but new head....</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C »</TD></TR><TR><TD CLASS="quote">Any 5w-30 dino oil will do the trick.
any oil period. the block is used..meaning the rings have already seated. (or atleast we hope lol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C »</TD></TR><TR><TD CLASS="quote">Is royal purple an ACEA A3 oil?
Modified by LSVT3K 91 C1V1C at 4:36 PM 10/3/2005</TD></TR></TABLE>
i don't think royal purple is..
pls do that oil test and keep us updated
