map sensor?
Ok I have a mini-me setup and going to swap a z6 manifold so that i can run newer style throttlebody with newer style IACV instead of dashpot and since i am going to run a turbo, where is the MAP sensor for the dx on a 91 crx, because i would like to use the missing link setup, so that the ecu does not read any boost..
or does the pm6 not have a MAP sensor?, and the only thing i need to do is block off the hole with a plate?
and for those who are asking why I am not swapping a y8 manifold, it is because this thing has been cut open and really been gutted out then extrude honed, so it flows like a motherf***er, and came with a bbk 62mm throttlebody
its on the back firewall it should have vac line running from it ( in front of the tb maybe 6" away from it
honda's need a map sensor
if you need any help just ask
i really don't want to run check valves, i know they work, i just want everything to look very clean..
i did do some research , and i have two options block off the z6 one , or bypass the stock one and use the z6 one, i think i will go with the z6 and missing link
thanks for the replies guys will post my setup when i am done
rice a roni
Sep 16, 2005 10:37 AM
