kteller 3 inch exhaust has a slip joint just use u bolts?
i just got in my kteller 3 inch exhaust and at one point of it it has a slip joint instead of a flange, do i just use a couple u bolts?
and to anyone else who has the exhaust where did you get the flanges you need and the bolts for the exhaust because mine didnt come with any. also what size bolts, thanks vernon
For the flanges and bolt/nuts, just go to your local exaust shop and get them. As for the joints, I'm not sure that the U-bolts will work correct. I had the exact same kit and had to do some cutting on mine for it to fit right so, I just welded all of it. Hope that helps. Later.
Phil
Phil
aleeterninja
Apr 25, 2015 09:52 AM
au-gsr
Nov 13, 2002 04:37 PM
