low beam conversion????
how do you do the conversion of putting 9005s in the low beams
is it bad for the car
does it run hotter.
will it ruin anything?
if someone can explain this to me that would be cool
thanks
do you guys run 9005 zenon bulbs in the low beams?
does it run hotter.
thanks
Nothing is inherently wrong with this conversion.
Lows = 51-55W
Highs = 60-65W
Not a great amount of difference there.
If the high beams can take 65W, so should the low beams.
Put some dielectric grease on the connec tions before installing, too.
Lows = 51-55W
Highs = 60-65W
