solid check light and abs light
Old Oct 2, 2005 | 06:38 AM
ybaws's Avatar
Default solid check light and abs light
i have a 2000 honda civic
when i turn the key to power on i get a solid abs and check light
however when i start the engine the lights go away. could any one tell me what's the problem
thanks.
Old Oct 2, 2005 | 06:46 AM
Chiovnidca's Avatar
Default Re: solid check light and abs light (ybaws)
Probably none. Have you checked for trouble codes?
Old Oct 2, 2005 | 06:50 AM
Shaun's Avatar
normal?... does the car start up with a CEL ?
Old Oct 2, 2005 | 09:13 AM
ybaws's Avatar
Default Re: solid check light and abs light (Chiovnidca)
well i have'nt check for any error codes but i have disconnected my oxygen sensor and no check light came on after the engine started.
Old Oct 2, 2005 | 09:59 AM
Turbo_y8's Avatar
so when you turn your car on those to lights come on then go away if so everything is fine if one stayes you have a prob, just use a paper clip and jump the connnector check the flashes
Old Oct 2, 2005 | 10:36 AM
ybaws's Avatar
Default Re: solid check light and abs light (tuck'd98)
where go i go to find the connectors
1slowcrx
Dec 6, 2011 04:51 AM
1slowcrx
Dec 5, 2011 01:30 PM
ybaws
Oct 8, 2005 10:57 AM
Corporation
Aug 21, 2005 08:55 PM
huepowered
Jul 6, 2004 06:16 AM
