not going into gear already searched
Old Oct 2, 2005 | 01:55 AM
boostng r's Avatar
a
Default not going into gear already searched
ok need good help werid problem
ok i was racing at the track i went into 4th gear and it did not go in i reline so i slow down to pdead stop now its hard to put back into any gear but when the car is off it shifts fine
i checked oil level in tranny the clutch and slave cylinder are good i dont know what else only when the car is on and the pedal is all the way done it so hard to
put in gear
its a type r tranny
thanks
Old Oct 2, 2005 | 10:18 AM
boostng r's Avatar
a
**** no one can help
Old Oct 2, 2005 | 11:01 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: not going into gear already searched (b16coupe4)
Might be synchos or try changing the fluid to Pennzoil Synchromesh. Worked for me.
Old Oct 2, 2005 | 11:21 AM
boostng r's Avatar
a
ok no one in hell all the synros allwent out and i already that pennzoil stuff
Old Oct 2, 2005 | 11:47 AM
coquitlamEG's Avatar
if the problem's not inside your transmission, the only other thing i can think of is that you might have slightly bent your shift linkage. Seen it happen once before.
Old Oct 2, 2005 | 11:09 PM
boostng r's Avatar
a
ok guys it was the pressure plate just to let u guys know thanks again for all the poepl tried to help
Cohgarrr13
Honda Civic (2001 - 2005)
Jan 8, 2018 05:05 PM
Ricextacy
Transmission & Drivetrain
13
Mar 17, 2009 07:57 AM
slayersluck
Jan 13, 2007 11:36 PM
Lude@Heart
May 2, 2004 10:51 AM
tyflip2
10
Nov 14, 2003 11:49 PM
