PROBLEMS WITH MSD (HELP)
Old Oct 1, 2005 | 08:57 PM
Mr HYDE's Avatar
Default PROBLEMS WITH MSD (HELP)
so i have a msd 6al box with blaster ss and msd wires. i hooked it all up the way msd instructions. i removed the internal coil and cut the little screw taps off the wires that connect to the coil and wired them into the wires for the msd and ran the wires through the little rubber block the rest of the wires went through. i had all the other wires ran right according to the instructions (it is only 6 wires). well my problem is the car runs good for a few hours then i blow out the ignitor, i did this twice. 2 totally different ignitors went with. the first one lasted longer about a day before going out completely, the second with in a few hours. i put the dizzy back to stock with a new coil adn ignitor and hasnt happened again. does anyone know why i kept blowing ignitors out with my msd or have similar problems. i talked to a friend he told me msd claims you need to cut holes for heat issues. i dont know how much of this is true or if thats the reason why i was blowing them due to the heat.
sorry for the long read just dont want to let this msd go to waste. let me know what you think and i can answer more questions if you dont understand what i wrote
Old Oct 2, 2005 | 04:33 AM
MenaceL.A.671's Avatar
Default Re: PROBLEMS WITH MSD (Mr. HYDE)
check the wires you connected again.. it might be touching!
Old Oct 2, 2005 | 07:04 AM
Mr HYDE's Avatar
Default Re: PROBLEMS WITH MSD (m2slsvtec)
everything was taped up
Old Oct 2, 2005 | 07:57 AM
Mr HYDE's Avatar
i cant find anything about why i keep blowing ignitors. i dont wanna assume its the heat problem make vents and have it happen again
Old Oct 2, 2005 | 12:08 PM
on dspool's Avatar
did you set it up to run 4cyl.? you should have had to cut a wire on the msd box. i belive they come set to run 8cyl.
Old Oct 2, 2005 | 12:23 PM
Mr HYDE's Avatar
Default Re: PROBLEMS WITH MSD (da693)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da693 &raquo;</TD></TR><TR><TD CLASS="quote">did you set it up to run 4cyl.? you should have had to cut a wire on the msd box. i belive they come set to run 8cyl.</TD></TR></TABLE>
yea i had cut both wires before installing
Old Oct 3, 2005 | 07:24 AM
Mr HYDE's Avatar
anyone?????????
Old Oct 3, 2005 | 08:23 AM
Mr HYDE's Avatar
AHHH HELP PLEASE
Old Oct 3, 2005 | 01:30 PM
Mr HYDE's Avatar
cmonnnnn
Old Oct 4, 2005 | 02:07 PM
Mr HYDE's Avatar
a forum filled with people that have used msd and no one has an idea whats going on with mine ?
Old Oct 4, 2005 | 03:41 PM
Mr HYDE's Avatar
this is really aggrivating
Old Oct 5, 2005 | 01:27 PM
Mr HYDE's Avatar
ttt
Old Oct 5, 2005 | 02:55 PM
SpeedingHatch's Avatar
&lt;-- having same problem with MSD and ignitor issues, except I dont blow mine completely. Its after the car heats up for 20 minutes, then sputters and bogs all over the place.
I remember hearing something about MSD and arcing the current, so it messes the ignitor up.
BUMP for both of us
Old Oct 15, 2005 | 08:51 AM
Mr HYDE's Avatar
Default Re: PROBLEMS WITH MSD (SpeedingHatch)
mine completely kills the ignitor bump for help
Old Oct 15, 2005 | 11:47 AM
battleRex's Avatar
i have a b16a with blaster 2 coil and msd cap and plug wires and when it warms up, it bogs and spudders in low rpms too
Old Oct 15, 2005 | 01:03 PM
battleRex's Avatar
nvm, fixed mine, my firing order was backwards
Old Oct 20, 2005 | 01:34 PM
Mr HYDE's Avatar
Default Re: (battleRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by battleRex &raquo;</TD></TR><TR><TD CLASS="quote">nvm, fixed mine, my firing order was backwards</TD></TR></TABLE>
lol dam how long did u go with the wrong firing order, im surpised it was running
Old Oct 30, 2005 | 07:58 AM
Mr HYDE's Avatar
Default Re: (Mr. HYDE)
bump
Old Oct 30, 2005 | 08:11 AM
Kidnkorner's Avatar
MSD does have toll free tech support man. I hope you find a solution!!!!!!!!
Old Oct 30, 2005 | 09:08 AM
darrinbrewer's Avatar
Default Re: (Lynx Bus Type R)
i know some aftermarket ignitors will last like 1 or 2 days...are you using a OEM honda ignitor?
Old Oct 30, 2005 | 10:41 AM
Mr HYDE's Avatar
Default Re: (darrinbrewer)
yes
Old Oct 31, 2005 | 11:26 AM
96b18c's Avatar
same **** used to happen to me until I was fed up and took it out. It's not really even worth the money unless you're boosted, considering each ignitor is around 170 or so.
Old Oct 31, 2005 | 01:30 PM
Mr HYDE's Avatar
Default Re: (96b18c)
i am boosted, and im started to max out to stock ignition
Old Oct 31, 2005 | 01:49 PM
96b18c's Avatar
oh. Do you know if the same problems occur when using the digital 6 or the sci? isn't the dig6 much better for boost?
Old Nov 1, 2005 | 04:07 PM
Mr HYDE's Avatar
no idea never researched it, my consern is my problem now
