B16a1 head Gasket
Old Oct 1, 2005 | 06:31 PM
larful's Avatar
Default B16a1 head Gasket
My 91 crx Si b16a1, I need to replace head gasket . going to do the work myself whats the best route to not only replace the gasket but make it faster as well. Replacing head? with b16a2 head? where is best place to find a whole new head replacement. was looking around on Ebay at Type R heads, that could be kinda sketch... not seeing it in person first.
Old Oct 1, 2005 | 06:32 PM
kulangot's Avatar
Default Re: B16a1 head Gasket (CrX sI')
honda dealer...oem
Old Oct 1, 2005 | 06:39 PM
larful's Avatar
Default Re: B16a1 head Gasket (kulangot)
so just do gasket? I see GSR head complete for buy now 750 ... thinking that would be better upgrade to do at that same time its all apart. NO??
Old Oct 1, 2005 | 06:44 PM
kulangot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrX sI’ &raquo;</TD></TR><TR><TD CLASS="quote">so just do gasket? I see GSR head complete for buy now 750 ... thinking that would be better upgrade to do at that same time its all apart. NO??</TD></TR></TABLE>
if you get anything gsr get the block....
Old Oct 1, 2005 | 06:50 PM
larful's Avatar
got friend who wants to sell his UDSM gsr head to me for 400 bux, deliverd. Sounds like ok deal what would it do for my b16a1? horse power wise?
Old Oct 1, 2005 | 06:54 PM
kulangot's Avatar
not that much..i would just put the gsr cams in your b16 head....the b16 head is close to the type r head...but if you can get a gsr bottom end put with your b16 head and gsr cams you would have what is called a poor mans type r..
Old Oct 1, 2005 | 07:02 PM
larful's Avatar
thanks that steers me in right direction. so keep my head have it checked out for warpage .. maybe have it machined .. from the head gasket issue I have had. then put it back together with type R cams see that sounds good already have AEM cam gears. what it does right now i start it revs to 3k instantly billows white smoke and the rev's goo higher higher by the second till i shut it down. last owner got moistiure in motor, it only has 30k on it too. ... motor sounds strong as hell too... just like i said billowing smoke reving high... trying to figure my best plan attack
Old Oct 1, 2005 | 07:35 PM
CaliforniaHighwayPatrol's Avatar
http://store.yahoo.com/twincamtech/index.html
Old Oct 1, 2005 | 10:10 PM
gmoneyef's Avatar
Like you said, have the head checked out for warp and spend money having it port-n-polished. You can get better gains through this rather than waste on diff head.
Old Oct 2, 2005 | 11:08 AM
larful's Avatar
Default Re: (gmoneyef)
I was looking up on inet after what you said about the porrt and polish looks to be around 800 bux or so is that what you would expect to pay locally? it was a internet site that was charging that much for port and polish
Old Oct 2, 2005 | 11:15 AM
kulangot's Avatar
Default Re: (CrX sI')
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrX sI’ &raquo;</TD></TR><TR><TD CLASS="quote">I was looking up on inet after what you said about the porrt and polish looks to be around 800 bux or so is that what you would expect to pay locally? it was a internet site that was charging that much for port and polish </TD></TR></TABLE>
PP its going to do **** if your head is stock....
ryanmh22
Jun 24, 2012 10:01 AM
b18prl
Mar 4, 2003 11:17 PM
