Radiator Hose Temp
Old Oct 1, 2005 | 05:01 PM
silvsrt4's Avatar
Default Radiator Hose Temp
After driving on the highway I overheat at idle.
My top radiator hose is hot and the bottom is cold.
Is the thermostat stuck?
Old Oct 1, 2005 | 09:29 PM
EG2Driver's Avatar
Default Re: Radiator Hose Temp (silvsrt4)
i would think that ur thermostat is just not opening.....is ur fan not working as well?
Old Oct 1, 2005 | 10:12 PM
spoonhatchback2001's Avatar
the bottom hose being cooler is normal. hot coolant comes for the top hose cools threw the radiatior and returns in the bottom hose. you may need a new thermastat or fan switch. i would go ahead and just replace the thermastat its cheap reapair just need new switch and some new coolant
Old Oct 1, 2005 | 11:23 PM
silvsrt4's Avatar
The weird thing was that when it sky rocketed to H today the reserve tank filled to the top and a little fluid squirted out onto the intake. I ran the car around for a little bit about 3am and then let it run in the parking garage at idle for 5 mins and the temp never went up?
dsands7
Aug 21, 2012 10:29 PM
xolk88
10
Mar 18, 2010 05:18 AM
jwlee7ucla
Aug 7, 2007 03:48 PM
Civicracer17
Jun 23, 2006 03:50 AM
