Aluminum motor mounts available anywhere?
Old Oct 1, 2005 | 02:52 PM
O16581724 5 2 5's Avatar
Default Aluminum motor mounts available anywhere?
So out of frustration of my driver's side motor mount coming loose, i put Loctite on the bolts into the block. My lower bolt came loose, stripped the threads, then snapped the top bolt in the block. I tried an EZ out and the stud will not come out, basically, i want an aluminum mount to replace this that i can simply weld to my block.
Old Oct 1, 2005 | 02:54 PM
EG2Driver's Avatar
Default Re: Aluminum motor mounts available anywhere? (O16581724 5 2 5)
get the specs and get one machined out of a block of aluminum.....aluminum isnt as strong as steel tho
Old Oct 1, 2005 | 02:57 PM
Default Re: Aluminum motor mounts available anywhere? (deadend9009)
I saw that Hasport's are aluminum after posting this, but they're too freakin' expensive. I guess i can try taking the piece to a machine shop and have them try to make something similar.
Old Oct 1, 2005 | 05:03 PM
EG2Driver's Avatar
make sure u get it right.....i dont think u'd want ur engine dropping all of a sudden.....good luck bro
Old Oct 1, 2005 | 05:57 PM
You mean like it did.
I tried taking the mount apart and i can't get it to unbolt, i kind of need a whole new mount anyway as it was broken and i just filled it with Urethane. I know there's companies other than HASport that makes mounts for Hondas, but i can't find them, a friend of mine bought one with aftermarket mounts that weren't by them. I just need an aluminum driver's side mount.
ProjectEvilEj2
Dec 25, 2012 09:57 AM
cmamtower
Oct 23, 2010 08:53 AM
lsxtreme81
Welding / Fabrication
21
Mar 22, 2010 08:16 PM
miataguy
31
Apr 22, 2004 09:56 AM
PSU-TEG
Apr 30, 2003 08:55 AM
