i need to replace a wire in the wire clip!!!!!!!!!!!!!
Old Oct 1, 2005 | 02:09 PM
projektvtec's Avatar
Default i need to replace a wire in the wire clip!!!!!!!!!!!!!
basically wat the title says. how would i go about taking a wire out of the wire clip and reinsalling a new wire??
Old Oct 1, 2005 | 03:42 PM
slomofo's Avatar
GDD Member
If you have the means, please take a picture of your problem and post it, as your ability to explain the situation is obviously impaired.
Old Oct 1, 2005 | 04:02 PM
Default Re: (slomofo)
http://repo.jackmoves.com/albun42/SANY0567
click on the link. how would i take a wire out of that and put a new one in???
Old Oct 1, 2005 | 04:35 PM
B20TDC2's Avatar
Default Re: (projektvtec)
they sell pin out tools the insert into the clip and release the wire, i had a teacher that was an old audi and porsche tech that had lots of them. not sure where to get one though
edit try contacting someone at allied elec. they should beable to help you out
http://www.alliedelec.com/
Old Oct 1, 2005 | 06:35 PM
Default Re: (B20TDC2)
does n e one know any other ways to do it or is there only one way??
Old Oct 2, 2005 | 05:54 AM
Default Re: i need to replace a wire in the wire clip!!!!!!!!!!!!! (projektvtec)
bump
Old Oct 3, 2005 | 07:24 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projektvtec &raquo;</TD></TR><TR><TD CLASS="quote">does n e one know any other ways to do it or is there only one way??</TD></TR></TABLE>The terminal pin on each wire should have a little prong the snaps into the plastic plug. Sorta like a little spring-loaded barb that holds it in. Usually you can use a tiny jeweler's screwdriver to unhook it. The tool B20TDC2's talking about just goes in & unhooks that prong; much easier. Trying to root around with a little screwdriver is a PITA.
Old Oct 3, 2005 | 08:20 AM
amckee's Avatar
find a hobby shop in your area that sells brass tubing and buy a piece that will just slip over the terminal. push it in hard until it bottoms or you feel it sort of snap and you will be able to pull the wire out the back. should cost about a dollar.
Old Oct 3, 2005 | 09:04 AM
Lewdin' Incognito's Avatar
Default Re: i need to replace a wire in the wire clip!!!!!!!!!!!!! (amckee)
I noticed that that connector has hinges on it. Some don't require an extraction tool, depending on the style. Might take a few minutes for you to see how it comes apart, but open it up and see if that helps at all. You're going to have to do that anyway when/if you do use the extraction tool.
14bcoupe
Welding / Fabrication
12
Apr 19, 2005 11:20 AM
