Integra Struts
Old Oct 1, 2005 | 02:08 PM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Integra Struts
I was wondering what they looked like, I just bought a piar off ebay and needed to make sure the bottom of the strut was the correct one. Does it look like this photo:
or this one:
Basically does it have the bearing or is it a fork? Thanks.
Old Oct 1, 2005 | 02:14 PM
projectTeG's Avatar
bottom pick. unless you have the ITR suspension then the rears would be the bushing type.
Old Oct 1, 2005 | 02:16 PM
S2KILLA's Avatar
Default Re: Integra Struts (SupersonicBlueGSR)
OK ****!!! Umm Well how much do you think that the bottoms will be to replace? And are coilover bottom sleeves interchangable with other companies? If so please send link.
Old Oct 1, 2005 | 02:18 PM
areyoujealous's Avatar
front is like a can of soda
rear is a fork
Old Oct 2, 2005 | 10:25 AM
S2KILLA's Avatar
Default Re: Integra Struts (bling bling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupersonicBlueGSR &raquo;</TD></TR><TR><TD CLASS="quote">OK ****!!! Umm Well how much do you think that the bottoms will be to replace? And are coilover bottom sleeves interchangable with other companies? If so please send link.</TD></TR></TABLE>
Old Oct 2, 2005 | 01:59 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
That first pic is suspension for an EP3 Civic Si or an RSX.
The second pic is suspension for a 90-01 Integra or Civic.
Old Oct 2, 2005 | 04:43 PM
Kendall's Avatar
A lot of people on ebay don't use the actual pics of the item you're getting, just a pic of some random suspension that they use on all of their auctions in order to save time. Check the details with the seller.
Old Oct 3, 2005 | 04:12 AM
S2KILLA's Avatar
Default Re: (Kendall)
nope there the wrong ones. Does anyone know where I can get the bottom forks? Any info is neeeded.
Old Oct 3, 2005 | 04:35 AM
be.twenty's Avatar
Default Re: (SupersonicBlueGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupersonicBlueGSR &raquo;</TD></TR><TR><TD CLASS="quote">nope there the wrong ones. Does anyone know where I can get the bottom forks? Any info is neeeded.</TD></TR></TABLE>
bottom forks? only the front requires the bottom forks and those should unbolt from your stock suspension...
the rear has it's own built in forks which the rear lower arm goes in between.
Old Oct 3, 2005 | 04:37 AM
LL2009's Avatar
Default Re: Integra Struts (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">That first pic is suspension for an EP3 Civic Si or an RSX.
The second pic is suspension for a 90-01 Integra or Civic.</TD></TR></TABLE>
Old Oct 3, 2005 | 04:55 AM
S2KILLA's Avatar
Default Re: Integra Struts (LLEO245)
Well I may have been a little dishonest. I asked to see what the bottom of the stut looks like when in fact Its a full setup coilover. Should I swap for the ITR suspension or just go and buy the forks? Sorry for the confusion. At first I just wanted to see what they looked like and now I need to know how I can fix the problem.
Old Oct 3, 2005 | 04:59 AM
be.twenty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupersonicBlueGSR &raquo;</TD></TR><TR><TD CLASS="quote">Well I may have been a little dishonest. I asked to see what the bottom of the stut looks like when in fact Its a full setup coilover. Should I swap for the ITR suspension or just go and buy the forks? Sorry for the confusion. At first I just wanted to see what they looked like and now I need to know how I can fix the problem.</TD></TR></TABLE>
if you got the ITR coilovers for your GSR, you require rear itr lca's... that's it..
if you got the GSR coilovers, it's literally a direct bolt on.
in both cases, you reuse your front stock forks and brake line brackets
Old Oct 3, 2005 | 05:34 AM
S2KILLA's Avatar
Default Re: Integra Struts (da_truf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_truf &raquo;</TD></TR><TR><TD CLASS="quote">
in both cases, you reuse your front stock forks and brake line brackets</TD></TR></TABLE>
Thanks da_truf. Looks like Ill be searching for some ITR lca's any body have a set? Should I buy aftermarket or oem?
Old Oct 3, 2005 | 07:44 AM
honda_joe's Avatar
I have a set of ITR LCA's that I'm looking to sell.
The only problem is that one bolt is still stuck and its holding the shock in place. You can probably just drill it out or torch it out. Oh yeah and they could use a coat of paint. The guy I got them from started sanding them down for paint.
PM me if you're interested
Old Oct 3, 2005 | 10:51 AM
S2KILLA's Avatar
Default Re: Integra Struts (honda_joe)
Ok took a picture of what I have. Here they are. Im trying to get a hold of the company now and see if theyll sell me the forks or if there too much just go and gets some Itr lca's.
and this is what I thought I was getting:
Old Oct 3, 2005 | 08:37 PM
Community Builder
Just get ITR LCA's. It'll be alot less hassle I think than trying to swap out the 2 rear coilovers w/ a different kind, especially considering it was an eBay transaction.
Old Oct 3, 2005 | 08:40 PM
Kendall's Avatar
ITR LCA's go for less than a hundred bucks all day long and are a bit stronger than the non-ITR ones.
And Integra's have shocks, not struts.
Old Oct 4, 2005 | 04:11 AM
S2KILLA's Avatar
thanks for all the advice. I will be purchasing them soon. Also, can I reuse my bolts from my stock rear lca setup on the itr lca's? Basically Im asking if the bolt that holds the shock in place is reusable?
Old Oct 4, 2005 | 05:16 AM
Community Builder
Probably not, I'm guessing the ITR LCA bolts are longer, could be wrong, though.
I would probably just buy those new from a dealer or online parts retailer.
Old Oct 4, 2005 | 05:43 AM
S2KILLA's Avatar
Default Re: (PatrickGSR94)
any links to an online store?
Old Oct 4, 2005 | 06:56 AM
Community Builder
acuraautomotiveparts.org
acuraparts247.com
Old Oct 4, 2005 | 07:06 AM
be.twenty's Avatar
search the forum.. there's always somebody selling used itr lca's..
Old Oct 4, 2005 | 09:02 AM
S2KILLA's Avatar
Default Re: (da_truf)
Thanks again guys, I found the bolt I need, Its an expensive one though racking in all the way to $0.94. But I need 2 so thats really gonna break the wallet. Thanks again though. I appreciate the help.
Old Oct 4, 2005 | 09:31 AM
FULLY_BUILT_NA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupersonicBlueGSR &raquo;</TD></TR><TR><TD CLASS="quote">Thanks again guys, I found the bolt I need, Its an expensive one though racking in all the way to $0.94. But I need 2 so thats really gonna break the wallet. Thanks again though. I appreciate the help.</TD></TR></TABLE>
dude thats nothing. my dealership charges $5 for a washer.. but anyway, next time read carefully when you buy on ebay. stock photos dont show the exact item. check the part #'s, ask the seller, etc.
Old Oct 4, 2005 | 10:20 AM
S2KILLA's Avatar
Default Re: (FULLY_BUILT_NA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FULLY_BUILT_NA &raquo;</TD></TR><TR><TD CLASS="quote">
dude thats nothing. my dealership charges $5 for a washer.. but anyway, next time read carefully when you buy on ebay. stock photos dont show the exact item. check the part #'s, ask the seller, etc.</TD></TR></TABLE>
That was totally sarcasm at its finest my man. I **** out dollar bills. In case you didnt pick up on that one, thats also sarcasm. But yes I will check the item number for now on. Thanks.
