LS Tranny or GSR??
Old Oct 1, 2005 | 02:01 PM
dynamyks's Avatar
Default LS Tranny or GSR??
i have a b18b1 and i was planning on swapping in a GSR tranny...
i wanted faster acceleration with its slightly shorter gear ratios, but now i'd just like to kno if it would be better to stay with my LS tranny or go with the GSR for a turbo application...
i have a small t25 turbo that im just waiting to put on, usually i kno that longer gears are better for turbo, but the gear ratios arnt't too much diifrent from each other...
so which tranny would i be better off with?
Old Oct 1, 2005 | 02:13 PM
DAguyLS's Avatar
LS
Old Oct 1, 2005 | 03:34 PM
BrooX's Avatar
Default Re: LS Tranny or GSR?? (dynamyks)
You can always upgrade your LS tranny by adding in a Quaife LSD I think you should consider that.
Old Oct 1, 2005 | 04:03 PM
LSvtec03's Avatar
Default Re: (DAguyLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAguyLS &raquo;</TD></TR><TR><TD CLASS="quote">LS</TD></TR></TABLE>
how bout, no, scott?
get a gsr transmission.
Old Oct 1, 2005 | 04:15 PM
GolfIVTyBiggums's Avatar
Default Re: (LSvtec03)
The LS tranny is terrible. The myth that it is so much better for turbo is one made up by someone who couldnt drive, or had walmart tires. The gsr transmission will probably be newer too, and better for you to dog on. Free yourself from your oppressive transmission.
Old Oct 1, 2005 | 04:23 PM
ProJectCvic's Avatar
Default Re: (GolfIVTyBiggums)
GSR
Old Oct 1, 2005 | 05:05 PM
Dartanian's Avatar
A shorter geared car will accelerate quicker n than a long geared tranny regardless if it is boosted or not. The LS tranny &gt; GSR tranny for boost idea is just a myth.
Old Oct 1, 2005 | 05:15 PM
CaliforniaHighwayPatrol's Avatar
agreed
Old Oct 1, 2005 | 06:37 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (JDM VTACK)
LS, only because i have one with a quaife LSD, clutch, flywheel and love it!
Old Oct 1, 2005 | 07:08 PM
2uy
Guest
Posts: n/a
Default Re: (00IntegrAllmotoR)
to answer ur question a gsr tranny cost as much as a b16 tranny if u want a good quick trannmission get the b16 with lsd
Old Oct 1, 2005 | 07:46 PM
shermanyang's Avatar
Default Re: (2uy)
get the GSR tranny. it's probably the best tranny out there for any LS setup with stock rev limit. i've had 5 ls turbos and on 3 of them have swapped out the LS tranny for the GSR tranny. that **** people say about longer gears, "You'll boost longer so you're accelerating faster" is bs. you're boosting longer beause it takes that much longer to get to speed and because with the longer gears there's more load.
the ITR/B16 tranny is also great but IMO when i tried it, the LS rpm's just don't do well with the gears that are that short.
Old Oct 1, 2005 | 07:52 PM
verbol assassin's Avatar
Default Re: (shermanyang)
GSR, but, then you'll be reving at 4500 on the freeway. Gas mileage go down. Gas prices are up.
Its your pick.
Old Oct 1, 2005 | 07:57 PM
Default Re: (verbol assassin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verbol assassin &raquo;</TD></TR><TR><TD CLASS="quote">GSR, but, then you'll be reving at 4500 on the freeway. Gas mileage go down. Gas prices are up.
Its your pick.</TD></TR></TABLE>
you got it all wrong. 4.5k is going 90 mph and i don't think you'll be wanting to do that. at 80mph you'll be at 4k and 70mph 3.5k...and so forth.
Old Oct 1, 2005 | 08:00 PM
integra_si-vtec's Avatar
i think the Gsr tranny would be good. it seems perfect for turbo ls becuase its not too short such as the b16 or itr, and its not long like the ls
Old Oct 2, 2005 | 12:47 AM
Moogen Powah's Avatar
Default Re: (honda-tech'er)
GSR tranny would be my choice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">"You'll boost longer so you're accelerating faster" is bs. you're boosting longer beause it takes that much longer to get to speed and because with the longer gears there's more load.
Old Oct 3, 2005 | 05:55 AM
dynamyks's Avatar
anybody actaully have any experience with this setup?...
Old Oct 3, 2005 | 06:08 AM
aj96coupe's Avatar
Personally, i would say 98spec ITR/B16 w/LSD or GSR Shorter gears will help your time alot, and it will be so much fun
I have a b16 in my civic and i was driving to Sioux City for about a Hour at 85mph at 5k to 5.4k all the way and i still got 30mpg.
Old Oct 3, 2005 | 06:17 AM
ecks_fourttwo's Avatar
Default Re: LS Tranny or GSR?? (aj96coupe)
i have an ls tranny on my lsv setup right now and i think im going to switch to either a b16 or gsr.. the ls tranny is alright but if i want to get my moneys worth out of my lsv then im going to need to get a new tranny..or do what some of the other people on here said...lsd
Old Oct 3, 2005 | 08:20 AM
DsBananas94LS's Avatar
If you got boost then just keep the LS not for all the myths, just because your making power more power you make the less you gotta worry about gear ratio
Old Oct 3, 2005 | 09:40 AM
Korch94's Avatar
a shorter geared tranny will always accelerate faster than a longer geared tranny (WITH TRACTION)
if you are staying relatively low hp then a gsr or b16 tranny isn't gonna give u terrible traction. The only logic for going with a longer geared tranny on a street car is when the powerband is so rediculous that you can no longer keep the tires down in any gear
Old Oct 3, 2005 | 02:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynamyks &raquo;</TD></TR><TR><TD CLASS="quote">anybody actaully have any experience with this setup?...</TD></TR></TABLE>
i've had experience with all 3 trannies. GSR is by far my favorite tranny with the LS motor combo.
Old Oct 3, 2005 | 03:16 PM
Sack Master's Avatar
Default Re: LS Tranny or GSR?? (shermanyang)
I'm not gonna argue which tranny is better. Obviously on a stock motor a gsr tranny is better than an ls. Stock B-series motors really make no power until you are high in the rpm range so you need to keep the revs up.
But when a car is turbo charged and making a decent amount of torque wouldn't you want longer gears? It works so well in every other car in drag racing(but of course I'm always looking at things in a drag racing perspective). The less amount of shifting you have to do the better.
Old Oct 3, 2005 | 04:41 PM
LSvtec03's Avatar
Default Re: LS Tranny or GSR?? (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">But when a car is turbo charged and making a decent amount of torque wouldn't you want longer gears? </TD></TR></TABLE>
no.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">The less amount of shifting you have to do the better. </TD></TR></TABLE>
i'll be in 3rd doing 80, and you be in 2nd doing 60. we'll both be happy.
Old Oct 4, 2005 | 12:26 AM
dynamyks's Avatar
Default Re: LS Tranny or GSR?? (LSvtec03)
okay thanx everybody...i guess im going to go ahead and swap in a GSR tranny
Poey2
Aug 20, 2007 01:13 PM
Se-rv-Tak
Sep 5, 2003 01:07 PM
zbower7
Aug 22, 2003 05:58 AM
Ragezero76
May 13, 2002 02:24 AM
H22CIVIC
Oct 21, 2001 11:58 AM
