freaking broke a nut/screw..help
i was putting on my header and snap... and snap again. 2 of those bolts (i think that's what they are called) on the block where you install headers snapped off. anyway ideas?
Theyre studs
Go to the hardware store, buy a narrow drill bit for hard metal (not so thin that it snaps...) and an EZ out (I want to say its numer 2).
Drill a hole in the bolt and then use the EZ out to extract the stud.
Since EZ outs are reverse threaded, when you screw it in (to the left, not right) its removing the stud at the same time.
Its very easy! You can do this!
Then, you just need to replace the stud. You can use a stud/nut combo again, or just a bolt...but Id go with a stud/nut again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda »</TD></TR><TR><TD CLASS="quote">anybody clarify on an ez out?
you can try this , i got it to work once, the other had to take the head to a machine shop to be drilled and taped.
B20EF
May 16, 2008 09:20 PM
teamrpm2
May 6, 2008 09:21 PM
idriveadelsol7
Dec 19, 2005 01:52 AM
