Whats wrong with my dyno plot? (pic)
ok, so i go t rosen today to tune the Spec B's a little. Went there before with just intake and header, on stock cams, and put down 169.8 or so (With PS belt off, i've heard anywhere from 5-8 whp for that)... I go today, forgot to take the PS belt off, and the most i can muster out is 163.6...
if i retarded the exhaust gear too much, the car wouldn't start (couldn't lean it out anymore, already at -30% at idle)...intake is advanced a fair amount. Here's a pic of the plot, with a/f readout on the bottom, any help is appreciated.
By the way, i've since fixed the little dip around 3500 rpms.
looking at your A/F, it seems to me that you are running on the lean side, try richening up the mixture a bit. I would should for an 11.5:1 to an 12.5:1 A/F ratio.
So, that's a graph with Toda B's?
Or, before you tuned the B's?
Either way, yes, your A:F is on the lean side. You should be able to tune it closer to 13:1 w/ VAFC. Then, adjust your cam gears. Black R can give you some setting if you ask him.
Or, before you tuned the B's? Either way, yes, your A:F is on the lean side. You should be able to tune it closer to 13:1 w/ VAFC. Then, adjust your cam gears. Black R can give you some setting if you ask him.
yeah, they're bs..i've got no clue why i peakeda t 7700... i need to pay sakai or jack to tune them, b/c i obviously i can't tune them for ****.
nice to see the guinei pig car is still running....LOL. I still might just throw mine on. I ordered a vafc tonight.
brandon..with the black teg you pulled on so hard leaving richmond.
[Modified by tecnic1, 4:41 PM 3/3/2002]
i would, but i mean, every car is different, what worked for his probably won't work for mine. i'll just pay to get it done right.
I'm also thinking the dyno may be off a tad, Brian*Black99Si, who had previously put down 154 in his Si, Put down 129 today. only thing he cchanged was he got rid of his AEM. It also told us a couple months ago that bryan sprinkle put down like 150, when he runs 14.1 in the 1/4... i dunno, it's kinda funny.
[Modified by xjohnx, 8:10 PM 3/3/2002]
I don't think there is something wrong with your A/F graph. except for that area between 4,800 and 6,800 where you can correct it with a VAFC. I don't think either it is the cause of your lack of power at top end. You migh need some better tuning for your timming and cams position.
Question: Do you have the recommended Toda springs installed?
I was there too and my R with an Icebox and Timing at 18 degrees pulled 166.9hp and 120.3tq. So the dyno seems to have put out some accurate numbers for me.
I never said it wasn't accurate, just not consistent. like last time i went when i put the 169 down and brian put down 150, his car was about 4 tenths faster than me at the time. I dunno. I'll take it to the charlotte dyno and let jack do his magic. or steve
** The headache begins**
Bryan
