Oil leak only when car is started
Old Oct 1, 2005 | 12:08 PM
sheeve's Avatar
Default Oil leak only when car is started
filled my car up with oil yesterday and nothing leaked. then when i started her up oil just started pouring out as if the bolt in the pan wasnt it, but it is. anyone have any ideas?
Old Oct 1, 2005 | 12:35 PM
.Grimace's Avatar
footwork mastery
Default Re: Oil leak only when car is started (sheeve)
this happened to friend before kinda sounds dumb. are you sure when you put dipstick back in that you actually got it in the hole??? he missed the hole but it looked like it was in there and was leaking oil. just an idea
Old Oct 1, 2005 | 01:02 PM
MONSTERZC's Avatar
if you changed your oil you double gasketed the oil filter. easy fix just remove your oil filter and remove the gasket.
Old Oct 1, 2005 | 09:56 PM
crxdriver89's Avatar
Default Re: Oil leak only when car is started (MONSTERZC)
could be your oil pan gasket
mrspeedy69
14
Feb 5, 2012 11:48 AM
TheCrimsonGhost666
Jul 8, 2009 08:21 PM
MumBleZ_94gsR
May 30, 2009 03:26 PM
mwstrick
Jul 24, 2007 09:19 PM
