white creme in tail pipe
Old Oct 1, 2005 | 11:40 AM
benjamin's Avatar
Default white creme in tail pipe
i did a search and i know white smoke means blown head gsket or cracked sleave but what about white creme inside the tail pipe
Old Oct 1, 2005 | 05:58 PM
200cs's Avatar
Default Re: white creme in tail pipe (benjamin)
oil and water mixing causes a mixture that looks like a chocolate milkshake. This can be caused by a headgasket failure or some other internal engine failure like a cracked head or block. you could check by verifying if there is contamination in your oil or coolant. Is it running hot? Good luck...
Old Oct 1, 2005 | 06:56 PM
coronadrinker's Avatar
I think somebody really likes your ride
Old Oct 1, 2005 | 08:10 PM
Dave_B's Avatar
What happened to the white cream?
Dave who's to drunk to even think about the white cream?!!!111!!!......
When oil and water mix it does look like a milkshake. You may have a headgasket leak. I'd like to see pics to determine.
Old Oct 1, 2005 | 08:18 PM
Mythias's Avatar
Default Re: white creme in tail pipe (coronadrinker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coronadrinker &raquo;</TD></TR><TR><TD CLASS="quote">I think somebody really likes your ride </TD></TR></TABLE>
This is the very reason all replies, with exception for the only technical one, were deleted.
Old Oct 1, 2005 | 08:20 PM
Haleiwa-Brando's Avatar
Default Re: white creme in tail pipe (Mythias)
Hahaha! They were deleted!
So....heres a stupid question: What gives this by product it's white creaminess? Is it simply the water mixing with oil? Or is it a chemical reaction between the antifreeze and the oil?
Old Oct 1, 2005 | 09:48 PM
SecretAgent's Avatar
Default Re: white creme in tail pipe (Haleiwa-Brando)
no chemical reaction present, just a physical reaction. like water mixing with ATF fluid turns it into a strawberry milkshake. i think it was intentional when the desigen antifreeze, so it's easier to spot in oil.
civ97
Mar 31, 2009 07:56 PM
ELSUICIDA
13
Apr 4, 2007 06:07 PM
B00STED Si
Feb 3, 2005 10:52 AM
Layziebtnh055
10
Apr 16, 2004 02:22 PM
civictypenos
Aug 12, 2003 10:00 AM
