dizzy question
Old Oct 1, 2005 | 10:25 AM
KURUPTinc's Avatar
Default dizzy question
Will a coil fire off if it cant read the piston one sensor?
Old Oct 1, 2005 | 10:34 AM
RCautoworks's Avatar
Default Re: dizzy question (KURUPTinc)
I have seen distributors that had bad tdc sensors inside them, and the car still ran. So that should answer your question.
Old Oct 1, 2005 | 10:36 AM
KURUPTinc's Avatar
Default Re: dizzy question (90blackcrx)
ok just checking cause my car was throwing that code and then after i replaced the batter none of the gauge cluster works now checked all the fuses but nothing. none of the lights come on when i put the ignition in position two exept for the battery light
Old Oct 1, 2005 | 10:41 AM
Sure you hooked eveything back up ?
Old Oct 1, 2005 | 10:45 AM
KURUPTinc's Avatar
yeah the car ran fine and everything for like a week then i started to get no spark
Old Oct 1, 2005 | 10:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KURUPTinc &raquo;</TD></TR><TR><TD CLASS="quote">yeah the car ran fine and everything for like a week then i started to get no spark</TD></TR></TABLE>
So why did you replace the battery, sounds like a distributor problem.
Old Oct 1, 2005 | 10:49 AM
KURUPTinc's Avatar
it wasnt holding charge any more but after i put the new one in the cluster problem came up then the dizzy but it was throwing the tdc code before it stopped running
Old Oct 1, 2005 | 10:51 AM
So did you change the distributor ?
Old Oct 1, 2005 | 11:57 AM
KURUPTinc's Avatar
not yet but my biggest concern is the dash.
Old Oct 1, 2005 | 12:02 PM
ghost_ryder35's Avatar
i would swap in a known good distributer, check all grounds, and double check the battery is hooked up all good! never hurts to take a part and put back together.
bobbyk
Honda Civic (2006 - 2015)
Dec 23, 2014 09:13 PM
darkvision
Feb 15, 2010 11:51 AM
D16Z6racing
May 1, 2005 10:35 PM
STHPERFORMANCE
Feb 17, 2004 09:53 AM
