11.8cr ls-vtec compression test question?
Old Oct 1, 2005 | 08:54 AM
Quick99's Avatar
Default 11.8cr ls-vtec compression test question?
hello, i have a quick question about my new ls-vtec. I recently did a compression test on it and was wondering about the end result. I got 240psi across the board,
Setup: 1,500km on motor and dyno tuned...
B18A block, P30 head, skunk2 stage1 cams, oem head gasket, stock crank and rods, pr3 pistons, comp cams valve-train...
any information or input would be usefull, thanks for any help!
Old Oct 1, 2005 | 09:30 AM
fmrprojects's Avatar
thats good as long as they are all in the same range. my similar set-up did 235 all across at 72 degrees, the motor
Old Oct 1, 2005 | 10:30 PM
Quick99's Avatar
Default Re: (fmrprojects)
thx dude, i was just curious cause i've seen some b-series motors go upto about 250-260psi, i thought it was a little low. But atleast its 240psi across the board so i'm happy
DC_Legacy
Jan 20, 2011 10:46 AM
Bonestock98GS
Sep 7, 2009 12:43 PM
20vsleeper
Aug 23, 2007 06:27 AM
whoneedzvtec
Nov 27, 2005 08:52 AM
pootie.teng
Jun 2, 2005 10:32 PM
