after market gauges
I took out the stock one on the head out and screwed it in untill I just barely felt the threads start to cross adn then left it. Its never leaked and I can still screw the stock senser into the head. Its right under the distributer. It gives actual readings of what the coolant temp is inside the head.
it goes in the head of the motor, right under the Dizzy, there is already a stock sending unit in the head with "1" wire on it, take the wire off and cover it up with some tape or whatever else you wanna use, then take out the stock sending unit and put your after market sendin unit in.
Isaac-
Isaac-
Casey
Mar 18, 2004 10:22 AM
Chugger
Mar 3, 2003 07:04 PM
