Size of stock 92si swaybars
Old Mar 3, 2002 | 09:16 AM
KekeK-18's Avatar
Default Size of stock 92si swaybars
Who know what size is the stock front and rear swaybars on a 92 civic Si? Anyone want to get rid of thier's?
Old Mar 3, 2002 | 09:48 AM
mantic6t9's Avatar
Default Re: Size of stock 92si swaybars (b18cturbo)
The 92-95 si hb only have front sway bars. I'm not sure of the size either. If you want a rear sway bar you have two choices. You can buy gsr rear lower controll arms and use a sway bar made for the integra, or you can buy one made for your car that mounts to the shock to LCA bolt. I like the GSR setup better.
TurboBumblBee's Avatar
if i remember correct it is 14mm all 92-95 si, ex have the same sway bar if i remember correctly..
Old Mar 3, 2002 | 09:50 AM
JV's Avatar
JV
Who?
Default Re: Size of stock 92si swaybars (95CivicEX)
All 92-95 Civics only came stock with a front bar (Exc. Sedans)
The SI/EX came with 21-22mm
Front swaybars.........
[Modified by JV, 1:51 PM 3/3/2002]
Old Mar 3, 2002 | 09:51 AM
mantic6t9's Avatar
Ok the front sway bar on the 92-95 civic is 21mm. The gsr rear sway bar is 14mm. If you want to go cheap you can probly pic up the gsr LCAs and GSR sway bar for around $100 or cheaper.
Old Jul 7, 2003 | 06:29 PM
elwood's Avatar
Default Re: Size of stock 92si swaybars (mantic6t9)
Sorry to bring this back up, but I noticed that everyone thinks
that the ex/si had a 21mm front swaybar. The jdm eg6 had
the 21mm front swaybar. The usdm ex/si came with a 19mm
front swaybar. The rear swaybar on the ex 4dr was only a 13mm.
dropgear
18
Jan 23, 2013 10:36 PM
y2kferari
19
May 9, 2009 06:37 AM
shaggyeg6si
May 8, 2008 05:19 PM
2.3lcivic
Sep 27, 2007 09:46 AM
mike93eh
Feb 9, 2004 04:21 PM
