P0420:cat efficiency threshhold below limit...
Old Oct 1, 2005 | 06:44 AM
foxbody5l's Avatar
Default P0420:cat efficiency threshhold below limit...
I recently installed a header and "high flow" cat converter in my 98 civic EX and now I am getting a code P0420 because this "high flow" cat doesn't work all that well. How can I keep the light off and keep the new converter??? I was thinking of disconnecting just the signal return wire treminal (harness side) from the cat monitor sensor(down stream o2). Will the ECM be satisfied with a constant signal or 0 Volts or is it going to need to see a bias rich condition after the cat??? Is there something else that I should do in order to solve this problem???
Old Oct 1, 2005 | 07:06 AM
douspray's Avatar
Default Re: P0420:cat efficiency threshhold below limit... (foxbody5l)
just put a 02 sensor simulator on the second sensor.
Old Oct 1, 2005 | 08:48 AM
Relic1's Avatar
Default Re: P0420:cat efficiency threshhold below limit... (douspray)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by douspray &raquo;</TD></TR><TR><TD CLASS="quote">just put a 02 sensor simulator on the second sensor.</TD></TR></TABLE>
that would be the best way to get rid of the CEL.
blackouthx
Oct 2, 2007 07:14 PM
baiwldrnner
Honda Civic (2001 - 2005)
13
Jul 15, 2007 10:04 AM
BLUE EH3
14
Jun 19, 2005 10:16 PM
TypeRRRR
Aug 5, 2002 04:40 AM
