will skunk2 stage 2 cams work on stock valve train for now........
okay ive got a semi-built ls/vtec im getting a set of skunk2 stage 2's sunday well im still running stock springs and retainers right now as long as i dont rev past 8 grand will it be okay untill i can get them? i have the compression to run these cams just not the S&R's thanx
oh ya im runing jdm itr 25 over pistons b18a with b16 head stock headgasket and head milled 10 thousandths will stage 2's be right for this compression? thanx
[QUOTE=mattcivic]oh ya im runing jdm itr 25 over pistons b18a with b16 head stock headgasket and head milled 10 thousandths will stage 2's be right for this compression? thanx [/QUOTE
your compression will be fine for the stage 2's
You will not be ok on stock springs, do not try to run on your stocks or they will bind. Save your money and get a set of rocket gen 2 springs and retainers or a set of omnipowers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcivic »</TD></TR><TR><TD CLASS="quote">okay ive got a semi-built ls/vtec im getting a set of skunk2 stage 2's sunday well im still running stock springs and retainers right now as long as i dont rev past 8 grand will it be okay untill i can get them? i have the compression to run these cams just not the S&R's thanx </TD></TR></TABLE>
NO!!!!!!!!!!!!!
NO!!!!!!!!!!!!!
IggyBcool
16
May 14, 2005 05:57 PM
Combustion Contraption
14
Aug 16, 2003 04:11 PM
