For all you Honda Savvy...will this work?...
Old Sep 30, 2005 | 09:14 PM
L2Man's Avatar
Default For all you Honda Savvy...will this work?...
Does anyone knows the answer to the following:
I have bolted a 1989 B16A1 (GEN-0) head onto a 1994 B18C1 (GEN-2) Block. My problem is that the head is JDM and the plugs for the Vtec Solenoid and the distributor are different from my USDM harness. The amount of wires are the same and they look as if they serve the same functions. I have the GEN-0 harness plugs to make the change, but I am uncertain if it would work once it is all plugged. Any comments?!? Thank you...
Old Oct 1, 2005 | 08:38 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: For all you Honda Savvy...will this work?... (L2Man)
b16a is obd0 and white plug, your gsr is obd1 grey plug. You can use the vtec selenoid by changing the plug, but you will have to use an obd1 dizzy, you cannot use th obd0 dizzy unless you usean obd0 ecu
egb16pg
Mar 24, 2007 09:58 PM
nikech1
Sep 15, 2006 10:36 PM
strokedb16
Aug 18, 2006 08:03 AM
teg4life
Oct 14, 2004 11:22 AM
