Can a GEN-0 B16A1 Head work with a GEN-2 B18C1 Block? What happens with the distributor?
Old Sep 30, 2005 | 08:42 PM
L2Man's Avatar
Default Can a GEN-0 B16A1 Head work with a GEN-2 B18C1 Block? What happens with the distributor?
Does anyone knows the answer to the following:
I have bolted a 1989 B16A1 (GEN-0) head onto a 1994 B18C1 (GEN-2) Block. My problem is that the head is JDM and the plugs for the Vtec Solenoid and the distributor are different from my USDM harness. The amount of wires are the same and they look as if they serve the same functions. I have the GEN-0 harness plugs to make the change, but I am uncertain if it would work once it is all plugged. Any comments?!? Thank you...
Old Sep 30, 2005 | 09:03 PM
thaiphob's Avatar
Nikon!!!
Default Re: Can a GEN-0 B16A1 Head work with a GEN-2 B18C1 Block? What happens with the distributor? (L2Man)
just use your gsr dizzy and wiring.
Old Sep 30, 2005 | 09:28 PM
L2Man's Avatar
I actually have a 94 LS,... I am planning in modifying its harness to use on this new built motor...what is a dizzy...? ;-)
Old Sep 30, 2005 | 09:57 PM
Kendall's Avatar
Dizzy = Distributor
Old Oct 1, 2005 | 01:21 AM
riceball777's Avatar
yes it will all work
all you have to do is get the correct vtec solenoid and correct dizzy for your car. whether its obd1, obd2a or obd2b
and its gen 1 theres no such thing as a gen 0 b16 unless you ment obd 0
Old Oct 1, 2005 | 03:30 AM
JDM_sedan's Avatar
its not because they are JDM its cause they are obd0, thats why it doesnt plug in, yes you can just get an obd1 dizzy and rewire the 2 wires on the vtec solenoid
Old Oct 1, 2005 | 10:47 AM
L2Man's Avatar
Thank you all so very much! This saves me a lot of hassle and time. I'll post a picture of the motor when all done. You're all awesome.
L2Man
Oct 1, 2005 08:38 AM
Rod.
Feb 22, 2004 09:43 AM
stockegsix
Apr 16, 2003 08:41 AM
RAWB
Mar 20, 2003 01:35 PM
HX_Guy
Jan 3, 2002 01:32 PM
