??? CHANGING TIMING BELT... WHAT ELSE SHOULD I REPLACE TOO ???
Old Sep 30, 2005 | 04:28 PM
99_dc2's Avatar
Default ??? CHANGING TIMING BELT... WHAT ELSE SHOULD I REPLACE TOO ???
I WAS WONDERING WHAT OTHER THINGS DO I NEED TO REPLACE WHEN CHANGING MY TIMING BELT.
Old Sep 30, 2005 | 04:30 PM
DB8_TEG's Avatar
Default Re: ??? CHANGING TIMING BELT... WHAT ELSE SHOULD I REPLACE TOO ??? (99_dc2)
waterpump
Old Sep 30, 2005 | 04:44 PM
Kendall's Avatar
Go ahead and get a valve cover gasket as well. Also check the front main seal to make sure it's not leaking.
Old Sep 30, 2005 | 05:05 PM
LL2009's Avatar
Default Re: ??? CHANGING TIMING BELT... WHAT ELSE SHOULD I REPLACE TOO ??? (DB8_TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DB8_TEG &raquo;</TD></TR><TR><TD CLASS="quote">waterpump</TD></TR></TABLE>
Old Sep 30, 2005 | 05:16 PM
Lord Helmet's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Go ahead and get a valve cover gasket as well. Also check the front main seal to make sure it's not leaking. </TD></TR></TABLE>
That's basically it
Old Sep 30, 2005 | 05:20 PM
2G0S0R1's Avatar
New User
Default Re: (Lord Helmet)
Tensioner... but you knew that already
Old Sep 30, 2005 | 05:21 PM
tegrevboy's Avatar
might as well replace the tensioner pulley to the belt goes around it and if it fails it will cause a world of crap also ...The reason i say it could go out is because it does have a bearing in it and if you are going to be in there might as well replace it too..
Old Sep 30, 2005 | 05:40 PM
Funkin Flux's Avatar
when i changed my timing belt, i did all the belts.. since your taking all that **** off anyway.. why NOt? i replaced
- p/s, a/c , timing belt , alternator belt
-crankshaft and camshaft seals
-waterpump
Old Sep 30, 2005 | 05:41 PM
tegrevboy's Avatar
Default Re: (eonflux)
Absolutely......
Old Sep 30, 2005 | 06:28 PM
CNSK's Avatar
all the belts...
Old Sep 30, 2005 | 07:40 PM
ProjectLSVTEG's Avatar
Default Re: (CNSK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eonflux &raquo;</TD></TR><TR><TD CLASS="quote">when i changed my timing belt, i did all the belts.. since your taking all that **** off anyway.. why NOt? i replaced
-waterpump
if you're in there.... do it, it'll save time/trouble down the road. Preventative maintenance is the best kind!
Old Oct 1, 2005 | 12:43 AM
IntegraGSR23's Avatar
Default Re: (ProjectLSVTEG)
If you need them I have the alternator belt, PS belt, and tensioner spring. All OEM Brand New.
Let me know
doostin
Feb 1, 2009 04:45 PM
JohnnyDiablo
Sep 25, 2007 03:38 PM
GSE980
54
Jun 19, 2007 11:18 PM
vietnogi
Apr 18, 2005 11:26 AM
this name is gone
Nov 13, 2004 10:45 AM
