Lightweight flywheel tranny grinds
Old Sep 30, 2005 | 03:29 PM
sol_1320's Avatar
Default Lightweight flywheel tranny grinds
for people that have Lightweight flywheel does your tranny grind alot more?
Old Sep 30, 2005 | 03:39 PM
Kouki-EK9's Avatar
Default Re: Lightweight flywheel tranny grinds (sol_1320)
I've never heard of a flywheel making any difference. When you shift your transmission is seperated from the flywheel. I'd like to hear others' input about this.
Old Sep 30, 2005 | 03:47 PM
Bond's Avatar
Default Re: Lightweight flywheel tranny grinds (Kouki-EK9)
No. It has nothing to do with your tranny actually shifting gears. It only effects the power transferred from the engine to the tranny. What weight fly are you running? I am running a chromoly 8.36lbs. flywheel for 8 months now and haven't had any problems. I have never heard of anyone having grinds just because of a light weight fly.
Old Sep 30, 2005 | 03:49 PM
idriveadelsol7's Avatar
Default Re: Lightweight flywheel tranny grinds (Bond)
nopes... fidanza 8LBer over here. your transmission is jacked up.
Old Sep 30, 2005 | 03:53 PM
SuperSteve737's Avatar
Never had a problem with my lightweight flywheel and shifting... I think it's just your trans.
Old Sep 30, 2005 | 06:37 PM
sol_1320's Avatar
Default Re: (93civicB18C)
Thanks people
Old Oct 1, 2005 | 10:57 PM
sol_1320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond &raquo;</TD></TR><TR><TD CLASS="quote">What weight fly are you running? </TD></TR></TABLE>
8lbs..........when I floor it never grinds kinda wired .........when driving around town I need to let rpm drop down to like 1k before I shift into the next gear
Old Oct 2, 2005 | 02:12 PM
Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol_1320 &raquo;</TD></TR><TR><TD CLASS="quote">
8lbs..........when I floor it never grinds kinda wired .........when driving around town I need to let rpm drop down to like 1k before I shift into the next gear </TD></TR></TABLE>
Well I am also running a 8lb and have never had to do this. I think your tranny is what is causing this.
Old Oct 2, 2005 | 06:45 PM
sol_1320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond &raquo;</TD></TR><TR><TD CLASS="quote">Well I am also running a 8lb and have never had to do this. I think your tranny is what is causing this.</TD></TR></TABLE>
I'm pretty sure its the tarnny too..........
Old Oct 2, 2005 | 07:46 PM
Bond's Avatar
I was reading your other posts again and it sounds like a syncro problem. Basically when your rpms are slower (like said before, shifting at 1000rpm) the gear your moving into is matched a lot easier then at 7000rpm. Atleast that is what I undersand about how they work, but I could be wrong. What's your tranny fluid level at? Might want to check that before you go swapping one. It's worth a try I guess.
Old Oct 3, 2005 | 05:47 AM
Mista Bone's Avatar
D Tranny Guru
damn people blaming synchros, really now.
Old Oct 3, 2005 | 07:18 AM
IHateJDM's Avatar
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">damn people blaming synchros, really now.</TD></TR></TABLE>
with lightweight flywheels, you need to shift faster, or give it a little gas in neutral so that the revs don't fall too far while shifting. If you don't, you can wear out your synchros faster.
Old Oct 3, 2005 | 07:59 AM
Old Oct 3, 2005 | 08:25 AM
dantastic's Avatar
had a 8lb fidanza and CM stage 1 on my LS tranny. no grinding issues
Old Oct 3, 2005 | 09:10 AM
Sean Juan's Avatar
Default Re: (dantastic)
Mine grinds every now and then when I start the car. I pulled out the starter and also took off the tranny and the teeth look fine... I'm starting to think this grinding might be because of the flywheel. My buddy has a 240 and he says a lot of guys on his forum say that it does that in their cars. But if you're driving and something grinds, it could be your synchros, but probably not the flywheel.
Old Oct 3, 2005 | 10:46 PM
sol_1320's Avatar
Default Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">
with lightweight flywheels, you need to shift faster, or give it a little gas in neutral so that the revs don't fall too far while shifting. If you don't, you can wear out your synchros faster. </TD></TR></TABLE>
I gave it a try doing what u said and it actually does work notice the grinds went away, guess I'm not suppose to baby it and just drive it like I stole it Well kind of
Old Oct 4, 2005 | 05:23 AM
IHateJDM's Avatar
Default Re: (sol_1320)
in the long run its better for the tranny if you just give the motor some gas to prevent the revs from falling too far. Its just rev matching, but its not necessary unless you have a &lt;10lb flywheel.
Old Oct 4, 2005 | 09:05 AM
david
Guest
Posts: n/a
i'm at 8Lbs... it's freaking difficult as hell to drive. when i barely tap the gas pedal, it jumps to 2RPMs. everything i shift gears, i have to rev match otherwise i feel a jolt like i'm downshifting.
Old Oct 4, 2005 | 09:24 AM
IHateJDM's Avatar
Default Re: (david)
yeah, i've been running a 7lb on my daily driver for over a year now. I would never go back to a heavier flywheel. You just have to get used to it.
Old Oct 4, 2005 | 09:32 AM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">yeah, i've been running a 7lb on my daily driver for over a year now. I would never go back to a heavier flywheel. You just have to get used to it.</TD></TR></TABLE> I agree, ACT prolite here. No grinding problems myself..
Old Oct 4, 2005 | 09:59 AM
sol_1320's Avatar
Thanks again for all the help ..........people
Old Oct 4, 2005 | 11:21 AM
Sean Juan's Avatar
Default Re: (HondaFanatic708)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote"> I agree, ACT prolite here. No grinding problems myself..</TD></TR></TABLE>
I have the same one. I love the flywheel, but yea, it definitely takes some getting used to. Well worth it tho.
Old Oct 4, 2005 | 12:56 PM
Bond's Avatar
Default Re: (david)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david &raquo;</TD></TR><TR><TD CLASS="quote">i'm at 8Lbs... it's freaking difficult as hell to drive. when i barely tap the gas pedal, it jumps to 2RPMs. everything i shift gears, i have to rev match otherwise i feel a jolt like i'm downshifting.</TD></TR></TABLE>
I still have a problem with that myself every once and awhile. usually when 1st to 2nd shifting it gets kinda jerky. Usually on two jerks though. I just kind of push on the gas already as I let the clutch in.
Old Oct 4, 2005 | 01:26 PM
Mohsin's Avatar
fidanza here, no probs, had it for over 10k
Old Oct 4, 2005 | 01:33 PM
b18option's Avatar
fidanza since 15k, no problems so far
