For those of you using a d16y8 head what dizzy are you using?
I am hoping to pick up a d16y8 swap but I am not sure if I should get the dizzy from the motor (obd2a) or if I should use my d16z6 dizzy.
I thought i heard of the z6 head and y8 head mounting points being different could be wrong thought thats why I'm asking.
Help ASAP please. Hoping to get motor tonight or tomorrow.
-Shane
-Shane
with using the y8 head you can use your stock distributor if you are keeping it obd0. but yes the mounting holes are different between the y8 and z6 heads. so if you want to go obd1 there might be some problems. i don't know for sure though.
so ur OBD-1....if u want to stay obd1 just use ur z6 dizzy. u have to modify the dizzy brackets. if u had obd0, it would be easier....ur d16a6 dizzy bolts right into the y8 head....
i got the z6 motor and i had to modify the brackets on the a6 dizzy...i'm still obd0.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZTEKEF9 »</TD></TR><TR><TD CLASS="quote">so ur OBD-1....if u want to stay obd1 just use ur z6 dizzy. u have to modify the dizzy brackets. if u had obd0, it would be easier....ur d16a6 dizzy bolts right into the y8 head....
i got the z6 motor and i had to modify the brackets on the a6 dizzy...i'm still obd0.</TD></TR></TABLE>
No.
Use the OBD-II D16Y8 distributor for the OBD-I conversion. It works. It is internally the same as an OBD-I distributor.
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S »</TD></TR><TR><TD CLASS="quote">
No.
Use the OBD-II D16Y8 distributor for the OBD-I conversion. It works. It is internally the same as an OBD-I distributor.</TD></TR></TABLE>
wow i learned something diff today....all this time i was thinking obd1-obd2 where diff....internally
No.
No.
Yeah i thought that too. But isn't it a different plug? How do I go about doing this?
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S »</TD></TR><TR><TD CLASS="quote">Use the OBD-II D16Y8 distributor for the OBD-I conversion. It works. It is internally the same as an OBD-I distributor.</TD></TR></TABLE>
Good info and 100% correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive »</TD></TR><TR><TD CLASS="quote">Yeah i thought that too. But isn't it a different plug? How do I go about doing this?</TD></TR></TABLE>
Not sure if the plug is different or not. But if it is different, go to rywire.com and order a 0bd-2a to obd0 distributor harness, its like 25 bux.
EDIT: I meant to say obd-0 to obd 2a
Modified by Mach69 at 10:01 PM 9/30/2005
Modified by Mach69 at 10:02 PM 9/30/2005
haha I actually got a obdo-obd1 dizzy jumper harness right now
. so that kinda sucks I'll have to do another jumper harness
TravisCadello
14
Apr 12, 2009 10:37 AM
mike93eh
Jul 20, 2005 02:39 PM
