What do i want?
Old Sep 30, 2005 | 02:38 PM
ezeedee's Avatar
Default What do i want?
I want to get a 4th gen (92-95) prelude, but im not sure which trim level. I want the one with the 190 hp H22 vtec, is it the Si? please help me out. Thanks a lot.
Old Sep 30, 2005 | 02:42 PM
92hondalude's Avatar
Default Re: What do i want? (ezeedee)
you want the Si Vtec
Old Sep 30, 2005 | 02:44 PM
Jordans95si's Avatar
Default Re: What do i want? (92hondalude)
Old Sep 30, 2005 | 02:55 PM
ezeedee's Avatar
ok, thanks a lot.
are there any special things i should look for when buying one? what will my pricerange be (i dont wanna spend a whole lot more than 6-7 grand)
Old Sep 30, 2005 | 03:01 PM
prelude1897's Avatar
Get a VTEC model but I believe they started in 93 though, correct me if I'm wrong
Old Sep 30, 2005 | 03:21 PM
Lil. Cease's Avatar
^^^ yup the vtec models started in 1993... if u get a 1992 si u will get the h23 NON- vtec....... but who needs vtec anyways??? j/k....
Old Sep 30, 2005 | 03:37 PM
leebabin387's Avatar
be sure to get the SI vtec without the 4 wheel steering.
Old Sep 30, 2005 | 03:39 PM
ezeedee's Avatar
so i want a 93-95 prelude Si?
what is 4ws? 4 wheel steering? how does that work?
Old Sep 30, 2005 | 05:47 PM
plikit's Avatar
Default Re: (ezeedee)
You want the SI VTEC not just the SI.
The SI is 160HP NON-VTEC
The SI VTEC is 190HP VTEC
Old Sep 30, 2005 | 06:09 PM
optikal_blitz's Avatar
They stopped calling it the Si VTEC in 94, too, only 93 was the year for "Si VTEC."
4 wheel steering is a system that allows, yup you guessed it, 4 wheels to do the steering. Under 20 mph the rear wheels steer oppositely to the front wheels (tightens the turning radius). Above 20 mph they steer the same direction (up to 15 degrees, i think), this is for crisper lane changes and what not.
People tell you not to get the 4ws cause its more problematic electronically and functionally than the amount of good it does. Plus it makes the car heavier overall, and the prelude is a pig anyway.
happy prelude hunting. AVOID THE S model, unless you wanna do a swap and a bunch of other upgrading
Old Sep 30, 2005 | 06:13 PM
ezeedee's Avatar
Default Re: (optikal_blitz)
ok, im a little overwhelmed.
I want a prelude with a h22 vtec, without 4ws, its a si vtec in 93, but just a Vtec in 94? 94 is tha same as 95? it had obd-2 in 96 right? i dont want obd-2, so i want a 93-95 prelude (si) vtec depending on what year i want?
*takes a deep breath*
hondakidd03
Nov 15, 2009 11:14 AM
woah
Jun 25, 2007 12:41 PM
UA6 BALLER STATUS
Oct 23, 2003 07:11 PM
MentaL
Aug 10, 2002 07:00 AM
Import RP
Sep 6, 2001 01:16 PM
