Code 43...What could it be?
Old Sep 30, 2005 | 02:12 PM
JDM_EH2's Avatar
Default Code 43...What could it be?
Well I have a code 43 which is fuel supply system. Any idea why I would get this cell? The car runs abosolutly fine. I turn off the car and turn it backk on and the cel's gone. But it comes back every now and then. Anyone else have this code? How did you fix it?
Old Sep 30, 2005 | 04:56 PM
JDM_EH2's Avatar
Default Re: Code 43...What could it be? (JDM_EH2)
bump...could it be my fuel pump is going? i have a walbro 255 for my boost project...i can throw that in awhile
Old Sep 30, 2005 | 05:27 PM
Auex's Avatar
Had the same code. The engine blew before I got to the bottom of it. I would start by replacing the fuel filter.
Old Sep 30, 2005 | 06:12 PM
Jedi_Sol's Avatar
Helms manual says if the CEL 43 comes on with poor driveablity, then there is a problem with the fuel system.
Since you didnt mention you had any driveability problems, check for loose connections or breaks in the wires, especially around the o2 sensor.
I have the same problem. It comes on, i restart the car, it goes away. The car drives perfectly fine if the light stays on.
James
Old Sep 30, 2005 | 06:33 PM
JDM_EH2's Avatar
I'm gonna check over everything tomorrow. The drivability is fine...there is a slight bucking on deccel...but that's all...I wanna get to the bottom fo this!
Old Sep 30, 2005 | 06:44 PM
lshatch1.8's Avatar
damn guys that makes 3 of us i also have that and wanted to ask and post up but i didnt. Its code 43 car drives fine no problem nothin.. just a check engine light
Old Sep 30, 2005 | 06:49 PM
Luserkid's Avatar
Default Re: Code 43...What could it be? (lshatch1.8)
If its not effecting your drive check your gas cap. Take it off and put it back on with good clicks and reset the ecu.
Old Sep 30, 2005 | 07:08 PM
JDM_EH2's Avatar
Default Re: Code 43...What could it be? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">If its not effecting your drive check your gas cap. Take it off and put it back on with good clicks and reset the ecu. </TD></TR></TABLE>
I'm gonna go try that right now! It didn't start happening till I filled up the tank for the first time. I haven't had th car on the road for very long. And I drove it all the way home from Cleveland, OH with no problems or CELs
Old Sep 30, 2005 | 07:27 PM
lshatch1.8's Avatar
damn i usta drive my 97 civic with no cap for a long time if anyone else knows how to fix this post up plz
Old Sep 30, 2005 | 07:32 PM
JDM_EH2's Avatar
I just tightend the cap and cleared the CEL...so we'll see. Come to think of it, my ex-girlfriend left my gas cap at the gas station once and I didn't have one for the longest time and never got a CEL...so I don't think that's the problem...
Most of you guys having this problem...do your cars have swaps? I'm starting to think its a wiring issue or a loose connection somewhere...because the car drives fine...ut I'm super picky and just want piece of mind
Old Sep 30, 2005 | 07:57 PM
Ej1_coupe's Avatar
Check your o2 sensors. I had my CEL 43, replaced the the o2, and bam, ran like a charm. If you search around, like I did, most say to check the o2 first.
Old Sep 30, 2005 | 08:01 PM
JDM_EH2's Avatar
Default Re: Code 43...What could it be? (Ej1_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej1_coupe &raquo;</TD></TR><TR><TD CLASS="quote">Check your o2 sensors. I had my CEL 43, replaced the the o2, and bam, ran like a charm. If you search around, like I did, most say to check the o2 first.</TD></TR></TABLE>
Yeah I'm gonna check everything tomorrow. The car runs fine. It's just the CEL that bothers me...so I'd like to figure out what it is. Thanks I'll check the O2 tomorrow
Old Sep 30, 2005 | 08:41 PM
lshatch1.8's Avatar
mines almost brand new, anymore things you guys can think of?
Old Sep 30, 2005 | 09:23 PM
JDM_EH2's Avatar
I personally think it's an electircal connection issue...since the car runs fine.
Old Oct 1, 2005 | 01:32 AM
Jedi_Sol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EH2 &raquo;</TD></TR><TR><TD CLASS="quote">IMost of you guys having this problem...do your cars have swaps? </TD></TR></TABLE>
I never had this cel with the z6.
James
eg6559
Dec 26, 2008 10:54 PM
jdm206
13
Dec 6, 2007 01:06 AM
mozzandherb
Dec 15, 2006 08:31 AM
str8JDMteggy
Sep 29, 2006 08:27 AM
PhilStubbs
Jan 22, 2005 11:20 AM
