1991 accord radio code?
radio got taken out and now i need the code to make it work again. anyone know what the code is? thanks in advance,and sorry for the stupid question,but i cant RIDE WITHOUT MUSIC!
You should have gotten a credit card size card with the number on it when the car was purchased. If you did't, you will have to find out from a dealer or by calling honda itself.
Some of the Honda's came with Bose radios.... still have an Anti-theft code. If you don't have it, you need to remove the radio, find the serial number and take the number to the dealer, (or call) and they should be able to get you the code. I could actually do the same for you.... if I had the serial number.
actually this car didnt come with that radio. its an acuras deck and this man hooked us up with it. anyway,i got the serial and i hope you can help me out. its: b20659273
thanks alot.
i dont have to press anything prior to those #'s or after right?
i do hope this works,because with my luck,i doubt it would.
either-way,i do appreciate you taking the time to help out.
Does the deck say "code"? it should say something... if not, i would check and make sure you have power going to the deck... and that the wires in the back are plugged in and not broken or anything. Other than that there isn't alot I can do. You gave me the serial number and I gave you the right code.... if there are other problems with the deck, you will need to address those first.
^yeah it does say code.
does it matter that its an ACURA deck though? this was most likely a deck she got from her husbands car or they bought it off a junkyard. ACURA dealer HERE was gay and not helpful.
Consider replacing it with a nice aftermarket, the prices have really plummeted in the past 5 to 10 years. You can pick up nice decks for under $100, or really nice new Alpines for $200 to $250.
yeah i am buying a deck,but the thing is i needed the code for this deck in the meantime. why? because before the NEW deck gets purchased-im spending my money on other things first.
