crank pulley
Old Sep 30, 2005 | 01:05 PM
FastGsr95's Avatar
Default crank pulley
I installed an unorthodox crank pulley and its not charging the battery correctly i hooked a honda alternator tester on it and it said insuffecient ripple which means its not charging correctly usually on customers cars when it says that we replace can anybody help
Old Sep 30, 2005 | 01:20 PM
Padawan's Avatar
Darth ModerVader
Default Re: crank pulley (FastGsr95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastGsr95 &raquo;</TD></TR><TR><TD CLASS="quote">I installed an unorthodox crank pulley and its not charging the battery correctly i hooked a honda alternator tester on it and it said insuffecient ripple which means its not charging correctly usually on customers cars when it says that we replace can anybody help</TD></TR></TABLE>
The UR pulley will not spin the alternator as fast as the stock one, so at low engine speeds you may measure lower-than-normal levels from the charging system.
Old Sep 30, 2005 | 04:27 PM
hybrid92b20's Avatar
i've had one on my car for like 2yrs and never had that prob. volts stay at 14.5 even at idle, but then again i dont have p.s. or a/c..
02Type-S
May 25, 2008 07:46 AM
CRX_RR
Mar 17, 2008 06:56 PM
street_ride14
May 14, 2007 08:44 PM
civiccoupe94
Jan 26, 2006 06:21 PM
