removing headlamps
Old Sep 30, 2005 | 11:02 AM
elitetuning's Avatar
Default removing headlamps
just need a general idea on how to remove the headlights on a 95 coupe do i need to remove the bumper or just take out the corner lams and then the headlights any help would be great
Old Sep 30, 2005 | 11:13 AM
Turbo_y8's Avatar
Default Re: removing headlamps (elitetuning)
you have to pull the clips along the top of the bumper under the hodd and then a bolt on each side of the bumper in the wheel well, and youll see the bolts that hold the headlights in, pretty easy stuff
Old Sep 30, 2005 | 11:15 AM
Ej1_coupe's Avatar
Default Re: removing headlamps (tuck'd98)
yepp.. take off bumper, take out headlights, you are going to need an extention for one of the headlight bolts though.
Old Sep 30, 2005 | 11:20 AM
thanks alot i was hoping to be able to do it in my driveway but i have lifts at my job ittl be easier on the lift it doesnt sound like i need to lift the car up though right the screws on the bumper seems rusted i tried to take them off with a basic screwdriver but didnt work can i use an impact driver to take them off
Old Sep 30, 2005 | 11:24 AM
JDM-EJ1's Avatar
Default Re: removing headlamps (Ej1_coupe)
Remove the bumper, remove each corner peice and you can see the bolts that hold the headlights in. There are 4 per light.
Old Sep 30, 2005 | 11:39 AM
IHateJDM's Avatar
Default Re: removing headlamps (JDM-EJ1)
no need for a lift. this can be done anywhere the car is parked. Also, be careful not to strip those screws.
Old Sep 30, 2005 | 01:41 PM
what happens if u did not saying i did maybe a little
Old Sep 30, 2005 | 01:44 PM
IHateJDM's Avatar
Default Re: (elitetuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elitetuning &raquo;</TD></TR><TR><TD CLASS="quote">what happens if u did not saying i did maybe a little</TD></TR></TABLE>
it will become a major PITA to remove the bumper. I only said that because I don't see how you could use an impact and not strip them. Just get the right screwdriver and they'll come off easily.
Old Sep 30, 2005 | 02:16 PM
Default Re: (IHateJDM)
u can use the impact driver just it the top wiht a hammer and it fully seats the head of the bit in the screw and then turn its more torque to get a stuck srew out but ur right though just get a biggerscrew driver
Old Sep 30, 2005 | 02:40 PM
Insane1mports's Avatar
You probably using a #1 screw driver. I believe those are #2 screw driver like most of the other ones.
Old Sep 30, 2005 | 03:29 PM
another question anyone know what sanpaper to use when painting rims i hbave ls wheels im going to paint with the new dupli color paint if i can find bronze but it says to scuff up the wheels what do i use to scuff them up any help would be great again
Old Sep 30, 2005 | 03:41 PM
Turbo_y8's Avatar
scotch brite pad, or a fine like 600 grit automotive sand paper
silverSOHC
Dec 30, 2006 12:41 PM
richboi
Mar 15, 2006 04:14 PM
diegospecaccord
Jun 20, 2005 08:31 AM
Jurassic Four
13
Jun 4, 2004 03:14 PM
2dregcivic757
Feb 26, 2003 05:14 PM
