Car won't go past 3500 RPM
Old Sep 30, 2005 | 09:55 AM
EckoTech
Guest
Posts: n/a
Default Car won't go past 3500 RPM
i was wondering if anyone could help me out, I was driving earlier today and my check engine light came on. After that evertime I got to 3500 RPM it got stuck, the car would just bog at that point. It did it in every gear at the same RPM. I was wondering if anyone has gone through the same thing? or might know what the problem may be? I was thinking it may be a TPS or MAP sensor? or some kind of sensor? thanks for taking your time to help me out!
Old Sep 30, 2005 | 09:56 AM
Ricey McRicerton's Avatar
Default Re: Car won't go past 3500 RPM (EckoTech)
Check your CEL. Your car is in limp mode.
Old Sep 30, 2005 | 11:40 AM
EckoTech
Guest
Posts: n/a
anyone else?
Old Sep 30, 2005 | 11:41 AM
Luserkid's Avatar
Ill help you but first tell me this. What code are you throwing?
Old Sep 30, 2005 | 11:50 AM
Default Re: Car won't go past 3500 RPM (Luserkid)
https://honda-tech.com/zerothread?id=1171263
Im in a particularly good mood today. There, use that to check your code.
Come back once you know what code it's throwing.
Old Sep 30, 2005 | 12:08 PM
EckoTech
Guest
Posts: n/a
Default Re: Car won't go past 3500 RPM (Ricey McRicerton)
k I just went out to check it, and now the CEL isn't coming on...? i turned the car on to see if maybe i was doing it wrong but the light doesn't come up anymore. So i revved it up past 3500rpm and its fine. Could it be its only going to do it when its really hot or something? if It comes up again i'll def check that out, Thanks Ricey McRicerton for the link, its saved under favs now. Well thanks guys I guess it was just a glitch or something.
Old Sep 30, 2005 | 12:11 PM
It's also stickied at the top of the forum.
And I just noticed you're in an ODBI car. There's some trick about having to check it while the cars on, but I don't really know. I've never owned an OBDI car.
Old Sep 30, 2005 | 05:57 PM
jh4da9's Avatar
When mine went into limp mode it was the ECT (coolant temp sensor) which is a code 6. Sometimes it would come on and other times it would not.
https://honda-tech.com/zerothread?id=1171263 Good info.
Old Sep 30, 2005 | 08:43 PM
VXJDMHATCH's Avatar
yeh my vx hatchback does the same crap when you floor it it boggs out and just turn's off i got a air intake temperature sensor was going off as well as a 02 sensor, which cost like over 400 dollars from dealer.... so i just gave up on it and im just swapping the damn thing.... i tried everything ....i heard someone say that it had somthing to do with the throttle positioning sensor or somthing im not sure ....
alex97
Apr 27, 2016 10:30 AM
jst17
Acura TSX
Mar 25, 2014 06:16 AM
TeknikDC2
Jan 24, 2007 06:38 AM
2DXtreme
Apr 1, 2005 11:00 AM
