are high flow convertors worth it?
Old Sep 30, 2005 | 08:35 AM
96 EX's Avatar
Default are high flow convertors worth it?
ive had mixed reviews about high flow convertors and was wondering do they really work and if so how much horse you gettin out of one? and is it worth the money really?
Old Sep 30, 2005 | 08:50 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: are high flow convertors worth it? (96 EX)
You won't get an insane improvement over stock and neither will you with a straightpipe. All that exhaust nonsense is not a BIG improvement in power, only on the butt dyno
Stay stock or get the high flow if your stock one is busted
Old Sep 30, 2005 | 09:03 AM
E-gg's's Avatar
Default Re: are high flow convertors worth it? (SkoundrelUSA)
well said. You gain good hp from it only if you have force induction setup. Otherwise, only a few gains at the top end where you lose some on the low end.
Old Sep 30, 2005 | 09:34 AM
deadlock32's Avatar
Default Re: are high flow convertors worth it? (E-gg's)
comparing hiflow to no cat the differences are minimal but the hiflow will keep the exhaust from sounding like total crap. if you are boosting then having one will make a difference. if not dont worry about it. if you do decide to pick on up make sure it is actualy a cat, and not a test pipe claiming to be a cat.
Old Sep 30, 2005 | 09:38 AM
komat's Avatar
Default Re: are high flow convertors worth it? (deadlock32)
i got a ebay test pipe. which is basicly a resonator
Old Sep 30, 2005 | 10:55 AM
civic_driver's Avatar
when your current cat goes to ****, put a high flow cat... otherwise don't bother
Old Oct 2, 2005 | 09:51 AM
E-gg's's Avatar
Actually, not all true on the sound. I compared my hi-flow CAT & the stock one w/ my current SC setup. The sound is the same and mine pass smog.
Old Oct 2, 2005 | 09:53 AM
Turbo_y8's Avatar
well you want for cheap i got a slightly used one ill let go for 30
Dukie432
11
May 15, 2009 07:07 PM
Slowboy!
15
Dec 17, 2005 12:37 AM
ohnoitssoysauce
Sep 12, 2004 10:53 AM
91jteg
Feb 18, 2004 09:57 AM
OneSloTeg
Oct 17, 2002 08:22 AM
