Question?
I read something that made me wonder... I read that the ring gears on the GSr trannies and the b16 trannies are different, isn't it possible to put the b16 tranny on a gsr engine?
The differentials themselves are different, not simply the ring gears.
But yes, you can put a B16 tranny on a GSR motor. The diff being different has nothing to do with the splines on the input shaft...
theres no need to swap clutch discs if both trannys are hydro the only time you would change the disc is if your tranny was a 90-91 and you where switching to a 92-93 tranny or vice versa but those are cable, long story short if there hydro you dont need to change clutches unless its bad, all hydro trannys have the same spline<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2-logicl »</TD></TR><TR><TD CLASS="quote">sweet so I just need to swap my clutch to a different one? If so I was planning on doing that anyhow... Just get a GSR clutch right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2-logicl »</TD></TR><TR><TD CLASS="quote">99-00 si tranny onto a 94 gsr block?</TD></TR></TABLE> yes you could put that tranny on any b series block as long as the clutch was right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2-logicl »</TD></TR><TR><TD CLASS="quote">I don't understand what you mean by if the clutch is right?</TD></TR></TABLE>what i mean is the splines in the clutch disc 90-91 have 1 spline less then a 92-93 94 and up all have the same amount of splines however the spline amount of a 92-93 is the same as a 94 and up b series .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2-logicl »</TD></TR><TR><TD CLASS="quote">so what you are saying is do not get a clutch for a 90-91 b series? If that is the case then I had no plans to do so.</TD></TR></TABLE>i was just breaking it down for you all i saying is this as long as the your b series has a 92 and up clutch on it any hydro b series tranny will fit
CapnKrunch
Nov 6, 2008 04:12 AM
92-LS-Civic
Jan 31, 2005 03:43 PM
turbo_ef9
Sep 6, 2004 05:12 AM
