CTR cams on B18C1...aftermarket cam gears a must???
Old Sep 30, 2005 | 06:29 AM
1JDMDOMINICAN's Avatar
Default CTR cams on B18C1...aftermarket cam gears a must???
Like the post says, I don't want to sound stupid, but i was wondering if I needed to have aftermarket adjustable cam gears on my motor in order to run CTR cams? My motor is bone stock right now, but I plan to start making upgrades to it soon and the cams are one of those upgrades. I'm assuming that since the CTR cams are OEM equipment on the Civic Type R, I wouldn't need adjustable cam gears like I would need say I was running Skunk 2 cams or something.
I know cam gears let u adjust many things, but I'm after just a bit of power from the cams and street driveability. Can anyone help me?
The car is a bone stock 97 GSR..save for the fact the header and exhaust are coming soon too.
By the way, could I use those cams with my OEM GSR intake manifold or would I hav eto upgrade to a Skunk 2 unit?
Old Oct 1, 2005 | 10:18 PM
dc24me's Avatar
Default Re: CTR cams on B18C1...aftermarket cam gears a must??? (mugenda6)
put the cams in. get a chipped ecu with a basemap for your setup and a harness from matt first.
Old Oct 2, 2005 | 09:36 AM
which harness, the one to convert my car to OBD II?
Do I still need to get adjustable cam gears?
Old Oct 2, 2005 | 11:12 AM
LSVTEC 91 Civic's Avatar
Banned
You don't need adjustable cam gears.
Old Oct 2, 2005 | 11:35 AM
rodimus's Avatar
Default Re: (LSVT3K 91 C1V1C)
if you have the money or the cam gears already, i would just get them installed along with the cams anyways, for future tuning purposes.
i would also get your car tuned..i've been told you would have to adjust the vtec point or you'll see some sort of dip in power or something.
Old Oct 2, 2005 | 01:41 PM
dc24me's Avatar
Default Re: (mugenda6)
the one that converts your car from obd2 to 1, so you can get a chippable ecu. you don't need cam gears unless your getting it tuned. the powerband on my car is so much smoother now i have the proper basemap. vtec kicks in at 5100 ish and the secondaries open up soon after.
Old Oct 3, 2005 | 05:58 AM
Default Re: (dc24me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc24me &raquo;</TD></TR><TR><TD CLASS="quote">the one that converts your car from obd2 to 1, so you can get a chippable ecu. you don't need cam gears unless your getting it tuned. the powerband on my car is so much smoother now i have the proper basemap. vtec kicks in at 5100 ish and the secondaries open up soon after.
looks like dats the way i'll be going..hard part would be getting a hold of matt..that guy is harder to get a hold of than the holy grail!
so the cam gears are not necessary then?
Old Oct 3, 2005 | 08:58 AM
sinister6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenda6 &raquo;</TD></TR><TR><TD CLASS="quote">
so the cam gears are not necessary then?</TD></TR></TABLE>
Not unless you going for a full tune w/ aftermarket ECU
Old Oct 5, 2005 | 06:31 AM
Default Re: (sinister6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister6 &raquo;</TD></TR><TR><TD CLASS="quote">
Not unless you going for a full tune w/ aftermarket ECU</TD></TR></TABLE>
ok, so what would recommend? I just want the car to have a little more power but sacrifice to much of its drivability...I don't want the car to get a rough idle or anything like that.
Old Oct 6, 2005 | 06:51 PM
sinister6's Avatar
i Dont think you will need aftermarket cam gear if you only running a CTR cam..its the biggest "stock" cam, and nothing close to the aftermarkets
Old Oct 7, 2005 | 04:32 AM
smkngsr's Avatar
u dont really need it, i mean u can get away by just simply doing a p28. But then, its always help somehome because when i tuned my car, my tuner adjusted my cam gears. I picked up few hp here in there just by simply tweaking the cam gears
t-powersi
Sep 13, 2007 09:06 PM
Kr4nG
Jul 13, 2007 02:02 PM
LsVtakYO
Dec 22, 2005 08:50 AM
StinkyTofu
Jan 4, 2002 09:35 AM
GSR
Oct 28, 2001 08:31 AM
