How would this turbo fair on a b16(pulsar T28)
Old Sep 30, 2005 | 05:58 AM
UNforgivABLE's Avatar
Default How would this turbo fair on a b16(pulsar T28)
Taken from cheapturbo.com,
Factory Nissan Pulsar GTiR T28
Dual Ball-Bearing
TURBINE SPECS: T28
.86 A/R Housing
79 Trim Wheel
COMPRESSOR SPECS: T3
.60 A/R Housing
60 Trim Wheel
Compressor Flow: 33 LB/MIN
internal wastegate included
How do you guys feel about this turbo?
My goals are 270-300whp with quick spool and hold strong to redline.
Old Sep 30, 2005 | 10:33 AM
Default Re: How would this turbo fair on a b16(pulsar T28) (Mort Goldman)
no one? I searched. Almost everything was for the smaller t28s.
Old Sep 30, 2005 | 01:02 PM
integracivic94's Avatar
i would also like to know cos i got one hooked up to my d16! just saving for fuel management so i have not run it yet!
Old Sep 30, 2005 | 01:48 PM
JalopySiR's Avatar
Search for my created posts... It may help.
Anyway, I've used one on a B20 with cams, Skunk2 IM, etc...
210whp and 190 tq at a measley 6 psi.
I had 175lbft by 3500. Sick. This was in a CRX.
Anyway, I think that would be a great turbo for a B16, and I would expect even higher numbers than mine at the same pressure.
If done properly.
Be aware, deviating from the "normal" T3 hot-side route opens the door for alot of headaches and trouble finding stuff that fits.
Feel free to pm with specific questions.
Old Sep 30, 2005 | 02:29 PM
Default Re: How would this turbo fair on a b16(pulsar T28) (JalopySiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JalopySiR &raquo;</TD></TR><TR><TD CLASS="quote">Be aware, deviating from the "normal" T3 hot-side route opens the door for alot of headaches and trouble finding stuff that fits.
Someone wanna explain this further? I know i need a manifold with a t25 flange, which ive found, what other things are different?
Old Sep 30, 2005 | 03:36 PM
Mag00n's Avatar
id like to know too.
Old Sep 30, 2005 | 04:00 PM
90civichbsi's Avatar
Default Re: How would this turbo fair on a b16(pulsar T28) (Mag00n)
its a good turbo for up too 300 hp, a friend of mine has a gtir, and his w/ intake, 3" exhaust, front mount, and greddy emanage made 320 hp at 14 psi.. this is on a 2.0.. but it would work really well for a low hp b16, very fast spool too
the gtir t28 is probably the better choice of any t28 just because it has a 79 tirm turbine as compared to the s14 64 trim.
and the t25 flanged manifold will work fine, the with a stock gtir turbo you would need an adapter like this for the compressor housing inlet http://www.atpturbo.com/Mercha...e=FLA as well as a 3 bolt compressor outlet flange
Modified by 90civichbsi at 1:15 AM 10/1/2005
Old Oct 1, 2005 | 08:40 PM
Default Re: How would this turbo fair on a b16(pulsar T28) (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">its a good turbo for up too 300 hp, a friend of mine has a gtir, and his w/ intake, 3" exhaust, front mount, and greddy emanage made 320 hp at 14 psi.. this is on a 2.0.. but it would work really well for a low hp b16, very fast spool too
Modified by 90civichbsi at 1:15 AM 10/1/2005</TD></TR></TABLE>
So you think 300whp is attainable with this turbo on a b16?
Old Oct 1, 2005 | 09:21 PM
Drew Peacock's Avatar
Yes they make about that on sr20 and that rwhp so should make 300fwhp quite easily.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mort Goldman &raquo;</TD></TR><TR><TD CLASS="quote">
So you think 300whp is attainable with this turbo on a b16?</TD></TR></TABLE>
Old Oct 1, 2005 | 09:33 PM
Mag00n's Avatar
Default Re: How would this turbo fair on a b16(pulsar T28) (turbozxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote">Yes they make about that on sr20 and that rwhp so should make 300fwhp quite easily.
nice signature
Old Oct 1, 2005 | 09:51 PM
Honda Sport
Jul 16, 2004 04:58 PM
jfoster
Apr 14, 2004 09:05 PM
Vtec92Civic
Nov 8, 2003 11:51 AM
delslow94
Jul 29, 2003 02:50 PM
poid
May 5, 2003 09:02 PM
