Painting stuff flat black?
Old Sep 30, 2005 | 02:57 AM
tEhNgUyeN's Avatar
Default Painting stuff flat black?
What are the steps to take if i wanted to paint anything flat black? I got a pair of stock civic sideskirts that are a little dirty and marked up and i would like to re paint them in flat black, would i just clean them off and get a can of flat black spray paint?
Old Sep 30, 2005 | 02:58 AM
ecahatch's Avatar
Senor Miembro
Default Re: Painting stuff flat black? (tEhNgUyeN)
you can just buy this paint called trim paint. and just follow direction from there.
if not, just clean em and spray
Old Sep 30, 2005 | 02:59 AM
EKFerioHawaii's Avatar
one trick that i have learned is to use black epoxy primer.
Not only does it sheen water better than aerosol black paint,
it serves a durable satin finish unlike traditional primer that
acts like a sponge and soaks up moisture and dirt.
Old Sep 30, 2005 | 04:15 AM
tEhNgUyeN's Avatar
Default Re: Painting stuff flat black? (EKFerioHawaii)
Would this stuff be at walmart or something or would i have to go to some auto place to pick it up? also how many layers should i do?
Old Sep 30, 2005 | 11:20 AM
tEhNgUyeN's Avatar
any reccomendations on how many coats i should do?
Old Sep 30, 2005 | 12:59 PM
integraXTC's Avatar
as many as you like. Start with at least 2-3 thin coats, and go from there. If you like it then stop. If not do another coat.
Old Sep 30, 2005 | 01:13 PM
jimmyxthai's Avatar
Default Re: (integraXTC)
yep the thinner the coats the flatter it will be
Old Sep 30, 2005 | 01:51 PM
tEhNgUyeN's Avatar
Default Re: (ludex360)
any brand recomendations?
Old Sep 30, 2005 | 01:56 PM
nerdsports's Avatar
you make it sound hard man...
go to walmart, kmart, home depot, your favorite spray paint supply store.
find trim paint (by duplicolor) or some other semi-flat black paint...
use soap and water to remove dirt and oil from the side skirts...
after theyre all dried, apply the paint.
follow the instructions on the can on how long to wait for another coat, etc...
good luck.
Old Oct 5, 2005 | 12:11 PM
tEhNgUyeN's Avatar
Default Re: (nerdsports)
well i never really painted anything.. and this is plastic and its my only pair of sideskirts so i just wanted to make sure.. what kind of grit sand paper could i use to just take out the scratches and rock chips?
Old Oct 5, 2005 | 04:50 PM
distortedfuture's Avatar
Default Re: (tEhNgUyeN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tEhNgUyeN &raquo;</TD></TR><TR><TD CLASS="quote">well i never really painted anything.. and this is plastic and its my only pair of sideskirts so i just wanted to make sure.. what kind of grit sand paper could i use to just take out the scratches and rock chips?</TD></TR></TABLE>play and learn, that's how i learned. do small baby steps and go from there till u like it. if not, start over.
Old Oct 5, 2005 | 05:29 PM
civicaleg's Avatar
go to a auto paint supplier. Ask for SEM brand Trim Black Paint in an aresol. This works great for exterior trim panels.
CaliforniaDad
Feb 21, 2010 09:47 PM
BoostedEgHatchFl
May 1, 2005 03:44 PM
Jasz
Mar 9, 2005 08:40 AM
dan_w_82
Feb 13, 2005 08:44 PM
PiYoImuT
Sep 27, 2002 02:52 PM
