Are DA LCAs the same as 89-91 CRX/Civic's?
Old Sep 29, 2005 | 11:16 PM
Deo's Avatar
Deo
Default Are DA LCAs the same as 89-91 CRX/Civic's?
I'm trying to put some CRX bushings into some DA LCA's and the bushing won't fit the strut mount with the inner sleeve in place. It looks like they might fit with the sleeves out, but I'm having quite a tough time getting the sleeves out to test it. The bushings kit reuses the sleeves pretty much everywhere else, so this is kind of odd.
On that note, anyone have any tricks for getting the sleeves out? A simple MAPP torch to the rubber got it out no problem, but these damned sleeves...
Modified by Deo at 12:47 AM 9/30/2005
Old Sep 29, 2005 | 11:18 PM
4potnick's Avatar
Default Re: Are DA LCAs the same as 89-91 CRX/Civic's? (Deo)
not sure about the bushings but I know that 88 civic and crx's have same rear trailing arms as type R.
Old Sep 29, 2005 | 11:50 PM
Deo's Avatar
Deo
Default Re: Are DA LCAs the same as 89-91 CRX/Civic's? (4potnick)
Yea, there are a few other threads on that issue. Due to complete lack of bushings for those LCAs (even the "right" set doesn't include strut bushings), so I'm switching to the more common setup. I happend to have DA LCAs sitting around leftover from my disc swap, but none for a CRX.
Old Sep 30, 2005 | 05:01 AM
crx_88_si's Avatar
hold em up to the CRX ones now then?
I do remember hearing they are 1/16" longer than crx parts
Old Sep 30, 2005 | 08:27 AM
Deo's Avatar
Deo
Default Re: (crx_88_si)
They're the same length, I just don't know about that middle bushing being the same diameter.
Old Sep 30, 2005 | 10:18 AM
Tyson's Avatar
theyre very different. DA arms are the oddball of all the arms. the shock bushing location relative to the inside/outside bushing is closer to the outside bushing.
i also noticed that the DA bushings have extra reinforcement in the rubber portion of the bushing. almost to make it stiffer.
i dont know if the bushings are compatible.
Old Sep 30, 2005 | 04:02 PM
Deo's Avatar
Deo
Default Re: (Deo)
EF Bushings fit if you remove the sleeve. One other concern though: suspension geometry... will it be close enough?
Everythings bolted up and ready to get an alignment tomorrow morning, I'm kind of crossing my fingers.
Old Sep 30, 2005 | 04:20 PM
Tyson's Avatar
Default Re: (Deo)
are you talking about polyurethane bushings?
and do you not have both arms available to look at? im assuming not, but then why not?
Old Sep 30, 2005 | 05:25 PM
Sgt_Ox's Avatar
Default Re: (Tyson)
the ED and DA rear LCA's share 2 of the same bushings (both outer ends). The center bushing on the DA LCA's are of different size (the bushing where the strut fork mounts over). This was my experience based on my HF rear LCA vs. the 90 DA rear disc that I did on my wifes 90 CRX HF.
Old Sep 30, 2005 | 05:58 PM
Deo's Avatar
Deo
Default Re: (Tyson)
Sorry Tyson, yes, I've been talking about poly bushings, my mistake.
Old Sep 30, 2005 | 06:56 PM
eda6's Avatar
Default Re: (Deo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ox5647 &raquo;</TD></TR><TR><TD CLASS="quote">the ED and DA rear LCA's share 2 of the same bushings (both outer ends). The center bushing on the DA LCA's are of different size (the bushing where the strut fork mounts over).</TD></TR></TABLE>
I found this out the hard way stranded at my friends house...
when i did my es bushing install i was using DA rear lcas. To get the sleeve out i had to buy a o2 sensor socket and modifiy it. After the sleeve was removed my new bushing was too small.
Ended up making an emergency trip to the junkyard to get some ee8 rear lcas.
Old Sep 30, 2005 | 07:10 PM
EG8R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick &raquo;</TD></TR><TR><TD CLASS="quote">not sure about the bushings but I know that 88 civic and crx's have same rear trailing arms as type R. </TD></TR></TABLE>
No not trailing arms. You mean rear lower control arms
artosaari33
Aug 25, 2010 11:05 AM
ef_hondas
15
Feb 5, 2010 06:34 PM
SiR Inspired ED7
Apr 11, 2006 07:54 PM
revvin9k
Dec 23, 2004 01:07 PM
kickz
Jan 31, 2003 01:42 PM
